LIFs are on invalid ports after upgrade
PDF of this doc site
Upgrade by using ARL
Use "system controller replace" commands to upgrade controller models in the same chassis
Creating your file...
Your file is ready
After the upgrade is completed, the FC logical interfaces (LIFs) might be left on incorrect ports if you have a MetroCluster configuration. You can perform a resync operation to reassign the LIFs to the correct ports.
Step
Enter the
metrocluster vserver resync
command to reallocate the LIFs to the correct ports.metrocluster vserver resync -vserver vserver_name fcp-mc.headupgrade.test.vs
