Persistenly disable the switches
You must disable the switches in the fabric persistently so that you can modify its configuration.
About this task
You disable the switches by running the commands on the switch command line; the commands used for this are not ONTAP commands.
Step
Persistently disable the switch:
For Brocade switches, use the
switchCfgPersistentDisablecommand. -
For Cisco switches, use the
suspendcommand.
The following command disables a Brocade switch persistently:
FC_switch_A_1:admin> switchCfgPersistentDisable
The following command disables a Cisco switch:
vsan [vsna #] suspend
