Retire node1
To retire node1, you must disable the HA pair with node2, shut node1 down correctly, and remove it from the rack or chassis.
Verify the number of nodes in the cluster:
cluster showThe system displays the nodes in the cluster, as shown in the following example:
cluster::> cluster show Node Health Eligibility --------------------- ------- ------------ node1 true true node2 true true 2 entries were displayed.
Disable storage failover, as applicable:
If the cluster is… Then… A two-node cluster
Disable cluster high availability by entering the following command on either node:
cluster ha modify -configured false-
Disable storage failover:
storage failover modify -node node1 -enabled falseA cluster with more than two nodes
storage failover modify -node node1 -enabled falseIf you do not disable storage failover, a controller upgrade failure can occur which can disrupt data access and lead to data loss. -
Verify that storage failover was disabled:
storage failover showThe following example shows the output of the
storage failover showcommand when storage failover has been disabled for a node:cluster::> storage failover show Takeover Node Partner Possible State Description -------------- -------------- -------- ------------------------------------- node1 node2 false Connected to node2, Takeover is not possible: Storage failover is disabled node2 node1 false Node owns partner's aggregates as part of the nondisruptive controller upgrade procedure. Takeover is not possible: Storage failover is disabled 2 entries were displayed. -
Verify the data LIF status:
network interface show -role data -curr-node node2 -home-node node1Look in the Status Admin/Oper column to see if any LIFs are down. If any LIFs are down, consult the Troublehsoot section.
Take one of the following actions:
Go to Step 6.
Go to Step 8.
Access the advanced privilege level on either node:
set -privilege advanced -
Verify that the cluster HA has been disabled:
cluster ha showThe system displays the following message:
High Availability Configured: false
If cluster HA has not been disabled, repeat Step 2.
Check whether node1 currently holds epsilon:
cluster showBecause there is the possibility of a tie in a cluster that has an even number of nodes, one node has an extra fractional voting weight called epsilon. Refer to References to link to the System Administration Reference for more information.
If you have a four-node cluster, epsilon might be on a node in a different HA pair in the cluster.
If you are upgrading an HA pair in a cluster with multiple HA pairs, you must move epsilon to the node of an HA pair that isn't undergoing a controller upgrade. For example, if you are upgrading nodeA/nodeB in a cluster with the HA pair configuration nodeA/nodeB and nodeC/nodeD, you must move epsilon to nodeC or nodeD.
The following example shows that node1 holds epsilon:
cluster::*> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------ ------------ node1 true true true node2 true true false
If node1 holds epsilon, then mark epsilon
falseon the node so that it can be transferred to the node2:cluster modify -node node1 -epsilon false -
Transfer epsilon to node2 by marking epsilon
trueon node2:cluster modify -node node2 -epsilon true -
Verify that the change to node2 occurred:
cluster showcluster::*> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------ ------------ node1 true true false node2 true true true
The epsilon for node2 should now be true and the epsilon for node1 should be false.
Verify whether the setup is a two-node switchless cluster:
network options switchless-cluster showcluster::*> network options switchless-cluster show Enable Switchless Cluster: false/true
The value of this command must match the physical state of the system.
Return to the admin level:
set -privilege admin -
Halt node1 from the node1 prompt:
system node halt -node node1If node1 is in same chassis as node2, do not power off the chassis by using the power switch or by pulling the power cable. If you do so, node2, which is serving data, will go down. -
When the system prompts you to confirm that you want to halt the system, enter
y.The node stops at the boot environment prompt.
When node1 displays the boot environment prompt, remove it from the chassis or the rack.
Optionally, decommission node1 after the upgrade is completed. See Decommission the old system.
