Retire node2
To retire node2, you must shut node2 down correctly and remove it from the rack or chassis. If the cluster is in a SAN environment, you also must delete the SAN LIFs.
Take one of the following actions:
If the cluster is… Then… A two-node cluster
Go to Step 2.
A cluster with more than two nodes
Go to Step 9.
Access the advanced privilege level by entering the following command on either node:
set -privilege advanced -
Verify that the cluster HA has been disabled by entering the following command and examining its output:
cluster ha showThe system displays the following message:
High Availability Configured: false
Check if node2 currently holds epsilon by entering the following command and examining its output:
cluster showThe following example shows that node2 holds epsilon:
cluster*::> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------ ----------- node1 true true false node2 true true true Warning: Cluster HA has not been configured. Cluster HA must be configured on a two-node cluster to ensure data access availability in the event of storage failover. Use the "cluster ha modify -configured true" command to configure cluster HA. 2 entries were displayed.
If you are upgrading an HA pair in a cluster with multiple HA pairs, you must move epsilon to the node of an HA pair that isn't undergoing a controller upgrade. For example, if you are upgrading nodeA/nodeB in a cluster with the HA pair configuration nodeA/nodeB and nodeC/nodeD, you must move epsilon to nodeC or nodeD. -
If node2 holds epsilon, mark epsilon as
falseon the node so that it can be transferred to node3:cluster modify -node node2 -epsilon false -
Transfer epsilon to node3 by marking epsilon
trueon node3:cluster modify -node node3 -epsilon true -
Verify if the setup is a two-node switchless cluster:
network options switchless-cluster showcluster::*> network options switchless-cluster show Enable Switchless Cluster: false/true
The value of this command must match the physical state of the system.
set -privilege admin -
Halt node2 by entering the following command on either controller:
system node halt -node node2 -
After node2 shuts down completely, remove it from the chassis or the rack.
Optionally, decommission node2 after the upgrade is completed. See Decommission the old system.
