Verify the health of the MetroCluster configuration
You should check the health of the MetroCluster configuration to verify correct operation.
Steps
Verify that the MetroCluster components are healthy:
metrocluster check runcluster_A::> metrocluster check run Last Checked On: 10/1/2017 16:03:37 Component Result ------------------- --------- nodes ok lifs ok config-replication ok aggregates ok 4 entries were displayed. Command completed. Use the "metrocluster check show -instance" command or sub-commands in "metrocluster check" directory for detailed results. To check if the nodes are ready to do a switchover or switchback operation, run "metrocluster switchover -simulate" or "metrocluster switchback -simulate", respectively.
Verify that there are no health alerts:
system health alert show
