Worksheet: Information to collect before and during controller upgrade
Contributors netapp-pcarriga netapp-aherbin
You should gather certain information to support upgrading the original nodes. This information includes node IDs, port and LIF details, licensing keys, and IP addresses.
You can use the following worksheet to record the information for use later in the procedure:
Information needed When collected When used Collected Information
Model, system ID, serial number of original nodes
Stage 1: Prepare the nodes for the upgrade
Stage 3: Install and boot node3
Stage 5: Install and boot node4
Stage 6: Decommission the old system
Shelf and disk information, flash storage details, memory, NVRAM, and adapter cards on original nodes
Stage 1: Preparing the nodes for the upgrade
Throughout the procedure
Online aggregates and volumes on original nodes
Throughout the procedure to verify that aggregates and volumes remain online except during brief relocation
Output of commands network port vlan show and network port ifgrp show
Stage 3: Map ports from node1 to node3
Stage 5: Map ports from node2 to node4
(SAN environments only) Default configuration of FC ports
When configuring FC ports on the new nodes
IP address of SPs
Stage 6: Confirm that the new controllers are set up correctly
License keys
IP address for the External Key Management server
Stage 1: Rekey disks for Storage Encryption
Stage 6: Set up Storage Encryption on the new nodes
Name and path of web-accessible directory where you download files to netboot the nodes
Stage 1: Prepare to netboot
Non-SAN data LIFs owned by node1
Stage 2: Move nonSAN data LIFs owned by node1 to node2
Later in the section
Cluster, intercluster, node-management, cluster-management, and physical ports
Stage 2: Record node1 information
Ports on new nodes
Later in the section and in the section Map ports from node2 to node4
Available ports and broadcast domains on node3
Non-SAN data LIFs not owned by node2
Moving non-SAN data LIFs belonging to node1 from node2 to node3 and verifying SAN LIFs on node3
Non-SAN data LIFs owned by node2
Stage 3: Move nonSAN data LIFs owned by node2 to node3
Stage 4: Record node2 information
Stage 5: Install and booting node4
Stage 5:_ Map ports from node2 to node4_
Cluster network ports on node4
Available ports and broadcast domains on node4
Private and public SSL certificates for the storage system and private SSL certificates for each key management server
