Install the new nodes and join them to the cluster
Contributors netapp-pcarriga
You must install the new nodes and join them to the cluster so that you can move volumes from the original nodes.
About this task
When you upgrade controller hardware by moving volumes, both the original nodes and the new nodes must be in the same cluster.
Step
  1. Install the new nodes and join them to the cluster:
    If the cluster is running…​ Follow instructions in…​
    ONTAP 9.0 or later
    Releases before ONTAP 9.0
What's next?
After installing and joining the new nodes, move Linux iSCSI hosts to the new nodes.
