Move internal drives from an original node
If your original node is one of the supported models, during the process of upgrading by moving storage you can move the node's internal SATA drives, SSDs, or SAS drives to a drive shelf that is attached to the new node in the same cluster.
You must have reviewed Considerations for upgrading controller hardware about moving internal drives.
Contact technical support if you need guidance specific to your configuration.
The SATA, SSD, or SAS drive carriers from the original node must be compatible with the new drive shelf.
A compatible drive shelf must already be attached to the new node.
The drive shelf must have enough free bays to accommodate the SATA, SSD, or SAS drive carriers from the original node.
You can move drives only within the same cluster.
Gently remove the bezel from the front of the system.
Press the release button on the left side of the drive carrier.
The cam handle on the carrier partially springs open, and the carrier releases from the midplane.
Pull the cam handle to its fully open position to unseat the carrier from the midplane, and then gently slide the carrier out of the drive shelf.
Always use two hands when removing, installing, or carrying a drive. However, do not place your hands on the drive boards exposed on the underside of the carrier. -
With the cam handle in the open position, insert the carrier into a slot in the new drive shelf, firmly pushing until the carrier stops.
Use two hands when inserting the carrier. -
Close the cam handle so that the carrier is fully seated in the midplane and the handle clicks into place.
You must close the handle slowly so that it aligns correctly with the face of the carrier.
Repeat Step 2 through Step 5 for all of the drives that you are moving to the new system.
After moving internal drives from the original node, attach storage shelves and reassign disk ownership.
