Prepare for the upgrade when moving volumes
Contributors netapp-pcarriga
You must perform a few preparation steps before upgrading controller hardware by moving volumes.
Steps
  1. Display the volumes on the original nodes:
    volume show
    You use the command output to prepare the list of volumes to move to the new nodes.
  2. Display and record license information from the original nodes:
    system license show
  3. If you use Storage Encryption on the original nodes and the new nodes have encryption-enabled disks, make sure that the original nodes' disks are correctly keyed:
    1. Display information about self-encrypting disks (SEDs):
      storage encryption disk show
    2. If any disks are associated with a non-manufacture secure ID (non-MSID) key, rekey them to an MSID key:
      storage encryption disk modify
  4. If the cluster is currently in a two-node switchless configuration, migrate the cluster to a two-node switched cluster using the type of switch you prefer.
  5. Send an AutoSupport message from each original node to inform technical support of the upgrade:
    system node autosupport invoke -node node_name -type all -message "Upgrading node_name from platform_original to platform_new"
What's next?
After preparing for the upgrade, install the new nodes and join them to the cluster.
