Shut down the original nodes
When shutting down and removing the original nodes you must send an AutoSupport message about the upgrade, destroy the mailboxes, power down the nodes, and remove the chassis.
Send an AutoSupport message from node1 and node2 to inform technical support of the upgrade:
system node autosupport invoke -node node_name -type all -message "MAINT=2h Upgrading node_name from platform_original to platform_new" -
Disable high availability or storage failover on node1 and node2:
If you have a… Enter… Two-node cluster
cluster ha modify -configured false -
storage failover modify -node node_name -enabled false
Cluster with more than two nodes
storage failover modify -node node_name -enabled false -
Halt the node:
system node halt -node node_nameYou can suppress the quorum check during the reboot process by using the
-ignore-quorum-warningsoption. -
Connect to the serial console, if you are not already connected. The node must be at the LOADER prompt. Use the
boot_ontap maintcommand to boot into maintenance mode.A message might appear asking you to confirm that the partner node is down or takeover is manually disabled on the partner node. You can enter
yesto continue. -
Record each original node's system ID, which is obtained through disk ownership information in Maintenance mode:
disk show -vYou need the system IDs when you assign disks from the original nodes to the new nodes.
*> disk show -v Local System ID: 118049495 DISK OWNER POOL SERIAL NUMBER HOME ---- ----- ---- ------------- ---- 0a.33 node1 (118049495) Pool0 3KS6BN970000973655KL node1 (118049495) 0a.32 node1 (118049495) Pool0 3KS6BCKD000097363ZHK node1 (118049495) 0a.36 node1 (118049495) Pool0 3KS6BL9H000097364W74 node1 (118049495) ...
If you have FC or CNA port configuration, display the configuration in Maintenance mode:
ucadmin showYou should record the command output for later reference.
*> ucadmin show Current Current Pending Pending Adapter Mode Type Mode Type Status ------- ------- --------- ------- ------- ------ 0e fc initiator - - online 0f fc initiator - - online 0g cna target - - online 0h cna target - - online ...
In Maintenance mode, destroy the node1 and node2 mailboxes:
mailbox destroy localThe console displays a message similar to the following:
Destroying mailboxes forces a node to create new empty mailboxes, which clears any takeover state, removes all knowledge of out-of-date plexes and mirrored volumes, and will prevent management services from going online in 2-node cluster HA configurations. Are you sure you want to destroy the local mailboxes?
Destroy the mailboxes by entering
ywhen you see a prompt similar to the following:.............Mailboxes destroyed Takeover On Reboot option will be set to ON after the node boots. This option is ON by default except on setups that have iSCSI or FCP license. Use "storage failover modify -node <nodename> -onreboot false" to turn it OFF. *>
Exit Maintenance mode:
halt -
Turn off the power to node1 and node2, and then unplug them from the power source.
Label and remove all cables from node1 and node2.
Remove the chassis containing node1 and node2.
After shutting down the original nodes, remove ownership of disks attached to the new nodes.
