Create new SAN LIFs or re-create deleted SAN LIFs
Depending on your cluster environment requirements, you might decide to create new SAN LIFs or re-create SAN LIFs that you deleted earlier in this procedure. You can create or re-create SAN LIFs by using the network interfaces creation procedure in the Cluster Management Using OnCommand® System Manager documentation.
