Migrate LIFs and data aggregates on node4 to node3
To complete the upgrade, you connect node3 to node4 and then migrate the data logical interfaces (LIFs) and data aggregates on node4 to node3.
At the LOADER prompt for node3, boot the node into the boot menu:
boot_ontap menu -
Select option
6 Update flash from backup configto restore the /var file system to node3.This replaces all flash-based configuration with the last backup to disks.
Enter
yto continue. -
Allow the node to boot as normal.
The node automatically reboots to load the new copy of the /var file system.
The node reports a warning that there is a system ID mismatch. Enter
yto override the system ID. -
Connect node3 to node4:
Attach multipath high availability (MPHA) cables to the NS224 shelf to ensure redundancy. Connect node3 100GbE port e0d to NSM B port e0b and connect node4 100GbE port e0d to NSM A port e0a.
Verify that HA ports e0a and e0b are connected between the nodes.
Verify that cluster ports e3a and e3b are connected between the nodes.
Migrate the cluster LIFs:
set -privilege advancednetwork port show -
Modify the cluster broadcast domain to include the desired cluster ports:
network port broadcast-domain remove-ports -broadcast-domain broadcast_domain_name -ports port_namesnetwork port broadcast-domain add-ports -broadcast-domain Cluster -ports port_namesBeginning with ONTAP 9.8, new IPspaces and one or more broadcast domains might be designated to existing physical ports that are intended for cluster connectivity. -
Modify the cluster IPspace to include the desired cluster ports and set the maximum transmission unit to 9000 if not already set:
network port modify -node node_name -port port_name -mtu 9000 -ipspace Cluster -
Display all cluster network LIFs:
network interface show -role cluster -
Migrate all cluster network LIFs on both nodes to their home ports:
network interface migrate -vserver vserver_name -lif lif_name -destination-node node_name -destination-port port_name -
Verify the home ports for the cluster network LIFs:
network interface modify -vserver vserver_name -lif lif_name -home-port port_name -
Migrate all data LIFs to node3:
Display all data network LIFs:
network interface show -role data -
Configure the home node and home port for all data LIFs. If any LIFs are down, set the administrative status of the LIFs to
upby entering the following command, once for each LIF:network interface modify -vserver vserver_name -lif lif_name -home-node node_name -home-port port_name -status-admin up -
Migrate the cluster management LIF:
network interface migrate -vserver vserver_name -lif cluster_mgmt -destination-node node3 -destination-port port_name -
Display the status of the cluster management LIF:
network interface show cluster_mgmt -
Display the status of all data aggregates in the cluster:
storage aggregate show -
Enable the HA pair, storage failover, and auto-giveback:
cluster ha modify -configured true -
Migrate data aggregates owned by node4 to node3:
storage aggregate relocation start -aggregate aggregate_name -node node4 -destination node3 -
Enable auto-revert of the network LIFs across the nodes:
network interface modify -lif * -auto-revert true -
Enable storage failover automatic giveback:
storage failover modify -node * -auto-giveback true -
Display the cluster status:
cluster show -
Display failover eligibility:
storage failover showIn the cluster report output, a node might incorrectly own aggregates that belong to another node. If this occurs, normalize by performing a takeover and giveback from both sides of the cluster. -
