Install and maintain
Restore encryption on the boot media in an AFF A20, AFF A30, or AFF A50 system using the manual boot recovery process
Contributors netapp-jsnyder netapp-lisa
Restore encryption on the replacement boot media in your AFF A20, AFF A30, or AFF A50 storage system to ensure continued data protection. The replacement process involves verifying key availability, reapplying encryption settings, and confirming secure access to your data.
Complete the appropriate steps to restore encryption on your system based on your key manager type. If you are unsure which key manager your system uses, check the settings you captured at the beginning of the boot media replacement procedure.
Onboard Key Manager (OKM)
Restore the Onboard Key Manager (OKM) configuration from the ONTAP boot menu.
Before you begin
Ensure you have the following information available:
Steps
On the impaired controller:
  1. Connect the console cable to the impaired controller.
  2. From the ONTAP boot menu, select the appropriate option:
    ONTAP version Select this option
    ONTAP 9.8 or later
    Select option 10.
    Show example boot menu
    Please choose one of the following:
    (1)  Normal Boot.
    (2)  Boot without /etc/rc.
    (3)  Change password.
    (4)  Clean configuration and initialize all disks.
    (5)  Maintenance mode boot.
    (6)  Update flash from backup config.
    (7)  Install new software first.
    (8)  Reboot node.
    (9)  Configure Advanced Drive Partitioning.
    (10) Set Onboard Key Manager recovery secrets.
    (11) Configure node for external key management.
    Selection (1-11)? 10
    ONTAP 9.7 and earlier
    Select the hidden option recover_onboard_keymanager
    (1)  Normal Boot.
    (8)  Reboot node.
    Selection (1-19)? recover_onboard_keymanager
  3. Confirm that you want to continue the recovery process when prompted:
    Show example prompt
    This option must be used only in disaster recovery procedures. Are you sure? (y or n):
  4. Enter the cluster-wide passphrase twice.
    While entering the passphrase, the console does not show any input.
    Show example prompt
    Enter the passphrase for onboard key management:
    Enter the passphrase again to confirm:
  5. Enter the backup information:
    1. Paste the entire content from the BEGIN BACKUP line through the END BACKUP line, including the dashes.
      Show example prompt
      Enter the backup data:
      --------------------------BEGIN BACKUP--------------------------
      0123456789012345678901234567890123456789012345678901234567890123
      1234567890123456789012345678901234567890123456789012345678901234
      2345678901234567890123456789012345678901234567890123456789012345
      3456789012345678901234567890123456789012345678901234567890123456
      4567890123456789012345678901234567890123456789012345678901234567
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      ---------------------------END BACKUP---------------------------
    2. Press Enter twice at the end of the input.
      The recovery process completes and displays the following message:
      Successfully recovered keymanager secrets.
      Show example prompt
      Trying to recover keymanager secrets....
      Setting recovery material for the onboard key manager
      Recovery secrets set successfully
      Trying to delete any existing km_onboard.wkeydb file.
      * Select option "(1) Normal Boot." to complete recovery process.
      * Run the "security key-manager onboard sync" command to synchronize the key database after the node reboots.
      Warning Do not proceed if the displayed output is anything other than Successfully recovered keymanager secrets. Perform troubleshooting to correct the error.
  6. Select option 1 from the boot menu to continue booting into ONTAP.
    Show example prompt
    * Select option "(1) Normal Boot." to complete the recovery process.
    (1)  Normal Boot.
    (8)  Reboot node.
    Selection (1-11)? 1
  7. Confirm that the controller's console displays the following message:
    Waiting for giveback…​(Press Ctrl-C to abort wait)
    On the partner controller:
  8. Giveback the impaired controller:
    storage failover giveback -fromnode local -only-cfo-aggregates true
  9. After booting with only the CFO aggregate, synchronize the key manager:
  10. Enter the cluster-wide passphrase for the Onboard Key Manager when prompted.
    Show example prompt
    Enter the cluster-wide passphrase for the Onboard Key Manager:
    All offline encrypted volumes will be brought online and the corresponding volume encryption keys (VEKs) will be restored automatically within 10 minutes. If any offline encrypted volumes are not brought online automatically, they can be brought online manually using the "volume online -vserver <vserver> -volume <volume_name>" command.
    Note If the sync is successful, the cluster prompt is returned with no additional messages. If the sync fails, an error message appears before returning to the cluster prompt. Do not continue until the error is corrected and the sync runs successfully.
  11. Verify that all keys are synced:
    security key-manager key query -restored false
    The command should return no results. If any results appear, repeat the sync command until no results are returned.
  12. Giveback the impaired controller:
  13. Restore automatic giveback if you disabled it:
  14. If AutoSupport is enabled, restore automatic case creation:
External Key Manager (EKM)
Restore the External Key Manager configuration from the ONTAP boot menu.
Before you begin
Gather the following files from another cluster node or from your backup:
  • /cfcard/kmip/servers.cfg file or the KMIP server address and port
  • /cfcard/kmip/certs/client.crt file (client certificate)
  • /cfcard/kmip/certs/client.key file (client key)
  • /cfcard/kmip/certs/CA.pem file (KMIP server CA certificates)
Steps
  2. Select option 11 from the ONTAP boot menu.
    (1)  Normal Boot.
    (8)  Reboot node.
    Selection (1-11)? 11
  3. Confirm you have gathered the required information when prompted:
    Show example prompt
    Do you have a copy of the /cfcard/kmip/certs/client.crt file? {y/n}
    Do you have a copy of the /cfcard/kmip/certs/client.key file? {y/n}
    Do you have a copy of the /cfcard/kmip/certs/CA.pem file? {y/n}
    Do you have a copy of the /cfcard/kmip/servers.cfg file? {y/n}
  4. Enter the client and server information when prompted:
    1. Enter the client certificate (client.crt) file contents, including the BEGIN and END lines.
    2. Enter the client key (client.key) file contents, including the BEGIN and END lines.
    3. Enter the KMIP server CA(s) (CA.pem) file contents, including the BEGIN and END lines.
    4. Enter the KMIP server IP address.
    5. Enter the KMIP server port (press Enter to use the default port 5696).
      Show example
      Enter the client certificate (client.crt) file contents:
      -----BEGIN CERTIFICATE-----
      <certificate_value>
      -----END CERTIFICATE-----
      Enter the client key (client.key) file contents:
      -----BEGIN RSA PRIVATE KEY-----
      <key_value>
      -----END RSA PRIVATE KEY-----
      Enter the KMIP server CA(s) (CA.pem) file contents:
      <certificate_value>
      Enter the IP address for the KMIP server: 10.10.10.10
      Enter the port for the KMIP server [5696]:
      System is ready to utilize external key manager(s).
      Trying to recover keys from key servers....
      kmip_init: configuring ports
      Running command '/sbin/ifconfig e0M'
      kmip_init: cmd: ReleaseExtraBSDPort e0M
      Show example
      Performing initialization of OpenSSL
  5. Select option 1 from the boot menu to continue booting into ONTAP.
    Show example prompt
    (1)  Normal Boot.
    (8)  Reboot node.
    Selection (1-11)? 1
  6. Restore automatic giveback if you disabled it:
  7. If AutoSupport is enabled, restore automatic case creation:
What's next?
After restoring encryption on the boot media, you need to return the failed part to NetApp.
