Enable onboard key management in ONTAP 9.6 and later
You can use the Onboard Key Manager to authenticate cluster nodes to a FIPS drive or SED. The Onboard Key Manager is a built-in tool that serves authentication keys to nodes from the same storage system as your data. The Onboard Key Manager is FIPS-140-2 level 1 compliant.
You can use the Onboard Key Manager to secure the keys that the cluster uses to access encrypted data. You must enable Onboard Key Manager on each cluster that accesses an encrypted volume or a self-encrypting disk.
You must run the security key-manager onboard enable command each time you add a node to the cluster. In MetroCluster configurations, you must run security key-manager onboard enable on the local cluster first, then run security key-manager onboard sync on the remote cluster, using the same passphrase on each.
Learn more about security key-manager onboard enable and security key-manager onboard sync in the ONTAP command reference.
By default, you are not required to enter the key manager passphrase when a node is rebooted. Except in MetroCluster, you can use the cc-mode-enabled=yes option to require that users enter the passphrase after a reboot.
 When the Onboard Key Manager is enabled in Common Criteria mode (
The Onboard Key Manager stores keys in volatile memory. Volatile memory contents are cleared when the system is rebooted or halted. Under normal operating conditions, volatile memory contents will be cleared within 30s when a system is halted. |
If you are using NSE with an external key management (KMIP) server, you must have deleted the external key manager database.
You must be a cluster administrator to perform this task.
You must configure the MetroCluster environment before you configure the Onboard Key Manager.
Start the key manager setup command:
security key-manager onboard enable -cc-mode-enabled yes|noSet cc-mode-enabled=yesto require that users enter the key manager passphrase after a reboot. The- cc-mode-enabledoption is not supported in MetroCluster configurations. Thesecurity key-manager onboard enablecommand replaces thesecurity key-manager setupcommand.The following example starts the key manager setup command on cluster1 without requiring that the passphrase be entered after every reboot:
Enter a passphrase between 32 and 256 characters, or for “cc-mode”, a passphrase between 64 and 256 characters.
If the specified “cc-mode” passphrase is less than 64 characters, there is a five-second delay before the key manager setup operation displays the passphrase prompt again.  -
At the passphrase confirmation prompt, reenter the passphrase.
Verify that the system creates the authentication keys:
security key-manager key query -node nodeThe security key-manager key querycommand replaces thesecurity key-manager query keycommand.Learn more about
security key-manager key queryin the ONTAP command reference.
Copy the passphrase to a secure location outside the storage system for future use.
The system automatically backs up key management information to the replicated database (RDB) for the cluster. You should also back up this information manually for disaster recovery.
