Replace a fan module in an AFF A20, AFF A30, or AFF A50 system
Replace a fan module in your AFF A20, AFF A30, or AFF A50 storage system when a fan fails or is not operating efficiently, as this can affect system cooling and overall performance. The replacement process involves shutting down the controller, removing the controller, replacing the fan, reinstalling the controller, and returning the failed part to NetApp.
If needed, you can turn on the storage system location (blue) LEDs to aid in physically locating the affected storage system. Log into the BMC using SSH and enter the system location-led on command.
A storage system has three location LEDs: one on the operator display panel and one on each controller. Location LEDs remain illuminated for 30 minutes.
You can turn them off by entering the system location-led off command. If you are unsure if the LEDs are on or off, you can check their state by entering the system location-led show command.
Step 1: Shut down the impaired controller
Shut down or take over the impaired controller using one of the following options.
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
If you have a SAN system, you must have checked event messages (
cluster kernel-service show) for the impaired controller SCSI blade. Thecluster kernel-service showcommand (from priv advanced mode) displays the node name, quorum status of that node, availability status of that node, and operational status of that node.Each SCSI-blade process should be in quorum with the other nodes in the cluster. Any issues must be resolved before you proceed with the replacement.
If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=<number of hours down>hThis prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with
MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.The following AutoSupport message suppresses automatic case creation for two hours:
Disable automatic giveback:
Enter the following command from the console of the healthy controller:
Enter
ywhen you see the prompt Do you want to disable auto-giveback?
Take the impaired controller to the LOADER prompt:
If the impaired controller is displaying… Then… The LOADER prompt
Go to the next step.
Waiting for giveback…
Press Ctrl-C, and then respond
ywhen prompted.System prompt or password prompt
Take over or halt the impaired controller from the healthy controller:
storage failover takeover -ofnode impaired_node_name -halt trueThe -halt true parameter brings you to the LOADER prompt.
You must have confirmed that the MetroCluster Configuration State is configured and that the nodes are in an enabled and normal state:
metrocluster node show
cluster1:*> system node autosupport invoke -node * -type all -message MAINT=2h -
Enter
Go to the next section.
ywhen prompted.System prompt or password prompt (enter system password)
Step 2: Remove the controller
You must remove the controller from the chassis when you replace the controller or replace a component inside the controller.
Make sure all other components in the storage system are functioning properly; if not, you must contact NetApp Support before continuing with this procedure.
On the impaired controller, make sure the NV LED is off.
When the NV LED is off, destaging is complete and it is safe to remove the impaired controller.
If the NV LED is flashing (green), destage is in progress. You must wait for the NV LED to turn off. However, if the flashing continues for longer than five minutes, contact NetApp Support before continuing with this procedure. The NV LED is located next to the NV icon on the controller.
NV icon and LED on the controller |
Always wear a grounded wrist strap connected to a verified ground point during installation and maintenance procedures. Failure to follow proper ESD precautions can cause permanent damage to controller nodes, storage shelves, and network switches. |
Disconnect the power on the impaired controller:
Power supplies (PSUs) do not have a power switch. If you are disconnecting a… Then… AC PSU
Open the power cord retainer.
Unplug the power cord from the PSU and set it aside.
DC PSU
Unscrew the two thumb screws on the D-SUB DC power cord connector.
Unplug all cables from the impaired controller.
Keep track of where the cables were connected.
Remove the impaired controller:
The following illustration shows the operation of the controller handles (from the left side of the controller) when removing a controller:
On both ends of the controller, push the vertical locking tabs outward to release the handles.
Pull the handles towards you to unseat the controller from the midplane.
As you pull, the handles extend out from the controller and then you feel some resistance, keep pulling.
Slide the controller out of the chassis while supporting the bottom of the controller, and place it on a flat, stable surface.
If needed, rotate the handles upright (next to the tabs) to move them out of the way.
Open the controller cover by turning the thumbscrew counterclockwise to loosen, and then open the cover.
Step 3: Replace fan
To replace a fan, remove the failed fan and replace it with a new fan.
Identify the fan that you must replace by checking the console error messages.
Remove the failed fan:
Hold both sides of the fan at the blue touch points.
Pull the fan straight up and out its socket.
Insert the replacement fan by aligning it within the guides, and then push down until the fan connector is fully seated in the socket.
Step 4: Reinstall the controller module
Reinstall the controller into the chassis and reboot it.
The following illustration shows the operation of the controller handles (from the left side of a controller) when reinstalling the controller, and can be used as a reference for the rest of the controller reinstallation steps.
If you rotated the controller handles upright (next to the tabs) to move them out of the way while you serviced the controller, rotate them down to the horizontal position. |
Push the handles to reinsert the controller into the chassis halfway and then, when instructed, push until the controller is fully seated. |
Rotate the handles to the upright position and lock in place with the locking tabs. |
Close the controller cover and turn the thumbscrew clockwise until tightened.
Insert the controller halfway into the chassis.
Align the rear of the controller with the opening in the chassis, and then gently push the controller using the handles.
Do not completely insert the controller in the chassis until instructed to do so. -
Connect the console cable to the console port on the controller and to the laptop so that the laptop receives console messages when the controller reboots.
Do not connect any other cables or power cords at this time. -
Fully seat the controller in the chassis:
Firmly push on the handles until the controller meets the midplane and is fully seated.
Do not use excessive force when sliding the controller into the chassis; it could damage the connectors. -
Rotate the controller handles up and lock in place with the tabs.
The replacement controller receives power from the healthy controller and begins to boot as soon as it is fully seated in the chassis.
Recable the controller as needed.
Reconnect the power cord to the power supply (PSU).
Once power is restored to the PSU, the status LED should be green.
If you are reconnecting a… Then… AC PSU
Plug the power cord into the PSU.
Secure the power cord with the power cord retainer.
DC PSU
Plug the D-SUB DC power cord connector into the PSU.
Tighten the two thumb screws to secure the D-SUB DC power cord connector to the PSU.
Return the impaired controller to normal operation by giving back its storage:
storage failover giveback -ofnode impaired_node_name -
Restore automatic giveback from the console of the healthy controller:
storage failover modify -node local -auto-giveback true -
If AutoSupport is enabled, restore (unsuppress) automatic case creation:
Step 5: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
