View node-level details in an ONTAP cluster
You can view node names, whether the nodes are healthy, and whether they are eligible to participate in the cluster. At the advanced privilege level, you can also display whether a node holds epsilon.
Steps
To view information about the nodes in a cluster, use the
cluster showcommand.If you want the output to show whether a node holds epsilon, run the command at the advanced privilege level.
Learn more about
cluster showin the ONTAP command reference.
Examples of displaying the nodes in a cluster
The following example displays information about all nodes in a four-node cluster:
cluster1::> cluster show Node Health Eligibility --------------------- ------- ------------ node1 true true node2 true true node3 true true node4 true true
The following example displays detailed information about the node named “node1” at the advanced privilege level:
cluster1::> set -privilege advanced
Warning: These advanced commands are potentially dangerous; use them only when directed to do so by support personnel.
Do you want to continue? {y|n}: y
cluster1::*> cluster show -node node1
Node: node1
Node UUID: a67f9f34-9d8f-11da-b484-000423b6f094
Epsilon: false
Eligibility: true
Health: true
