Rename an ONTAP node
You can change a node's name as required.
Steps
To rename a node, use the
system node renamecommand.The
-newnameparameter specifies the new name for the node. Learn more aboutsystem node renamein the ONTAP command reference.If you want to rename multiple nodes in the cluster, you must run the command for each node individually.
Node name cannot be “all” because “all” is a system reserved name.
Example of renaming a node
The following command renames node “node1” to “node1a”:
cluster1::> system node rename -node node1 -newname node1a
