Learn about ONTAP SMB read-only bits
The read-only bit is set on a file-by-file basis to reflect whether a file is writable (disabled) or read-only (enabled).
SMB clients that use Windows can set a per-file read-only bit. NFS clients do not set a per-file read-only bit because NFS clients do not have any protocol operations that use a per-file read-only bit.
ONTAP can set a read-only bit on a file when an SMB client that uses Windows creates that file. ONTAP can also set a read-only bit when a file is shared between NFS clients and SMB clients. Some software, when used by NFS clients and SMB clients, requires the read-only bit to be enabled.
For ONTAP to keep the appropriate read and write permissions on a file shared between NFS clients and SMB clients, it treats the read-only bit according to the following rules:
NFS treats any file with the read-only bit enabled as if it has no write permission bits enabled.
If an NFS client disables all write permission bits and at least one of those bits had previously been enabled, ONTAP enables the read-only bit for that file.
If an NFS client enables any write permission bit, ONTAP disables the read-only bit for that file.
If the read-only bit for a file is enabled and an NFS client attempts to discover permissions for the file, the permission bits for the file are not sent to the NFS client; instead, ONTAP sends the permission bits to the NFS client with the write permission bits masked.
If the read-only bit for a file is enabled and an SMB client disables the read-only bit, ONTAP enables the owner's write permission bit for the file.
Files with the read-only bit enabled are writable only by root.
The read-only bit interacts with the ACL and Unix mode bits in the following ways:
When the read-only bit is set on a file:
No changes are made to the ACL for that file. NFS clients will see the same ACL as before the read-only bit was set.
Any Unix mode bits that allow write access for the file are ignored.
Both NFS and SMB clients can read the file, but they cannot modify it.
ACLs and UNIX mode bits are ignored in favor of the read-only bit. This means that even if the ACL allows write access, the read-only bit prevents modifications.
When the read-only bit is not set on a file:
ONTAP determines access based on the ACL and UNIX mode bits.
If either the ACL or the UNIX mode bits deny write access, then NFS and SMB clients cannot modify the file.
If neither the ACL nor UNIX mode bits deny write access, then NFS and SMB clients can modify the file.
Changes to file permissions take effect immediately on SMB clients, but might not take effect immediately on NFS clients if the NFS client enables attribute caching. |
