View default certificates for TLS-based applications in ONTAP
ONTAP provides a default set of trusted root certificates for ONTAP applications using Transport Layer Security (TLS).
The default certificates are installed only on the admin SVM during its creation, or during an upgrade.
The current applications that act as a client and require certificate validation are AutoSupport, EMS, LDAP, Audit Logging, FabricPool, and KMIP.
When certificates expire, an EMS message is invoked that requests the user to delete the certificates. The default certificates can only be deleted at the advanced privilege level.
Deleting the default certificates may result in some ONTAP applications not functioning as expected (for example, AutoSupport and Audit Logging). |
You can view the default certificates that are installed on the admin SVM by using the security certificate show command:
security certificate show -vserver –type server-cacluster1::> security certificate show Vserver Serial Number Certificate Name Type ---------- --------------- ----------------------------------------- --------- vs0 4F4E4D7B www.example.com server Certificate Authority: www.example.com Expiration Date: Thu Feb 28 16:08:28 2013Learn more about
security certificate showin the ONTAP command reference.
