Enable onboard key management for NVE in ONTAP 9.6 and later
You can use the Onboard Key Manager to secure the keys that the cluster uses to access encrypted data. You must enable the Onboard Key Manager on each cluster that accesses an encrypted volume or a self-encrypting disk.
You must run the security key-manager onboard sync command each time you add a node to the cluster.
If you have a MetroCluster configuration, you must run the security key-manager onboard enable command on the local cluster first, then run the security key-manager onboard sync command on the remote cluster, using the same passphrase on each. When you run the security key-manager onboard enable command from the local cluster and then synchronize on the remote cluster, you do not need to run the enable command again from the remote cluster.
Learn more about security key-manager onboard enable and security key-manager onboard sync in the ONTAP command reference.
By default, you are not required to enter the key manager passphrase when a node is rebooted. You can use the cc-mode-enabled=yes option to require that users enter the passphrase after a reboot.
For NVE, if you set cc-mode-enabled=yes, volumes you create with the volume create and volume move start commands are automatically encrypted. For volume create, you need not specify -encrypt true. For volume move start, you need not specify -encrypt-destination true.
When configuring ONTAP data at rest encryption, to meet the requirements for Commercial Solutions for Classified (CSfC) you must use NSE with NVE and ensure the Onboard Key Manager is enabled in Common Criteria mode. See CSfC Solution Brief.
When the Onboard Key Manager is enabled in Common Criteria mode (
The Onboard Key Manager stores keys in volatile memory. Volatile memory contents are cleared when the system is rebooted or halted. The system clears volatile memory within 30 seconds when it is halted. |
You must be a cluster administrator to perform this task.
You must configure the MetroCluster environment before you configure the Onboard Key Manager.
Start the key manager setup:
security key-manager onboard enable -cc-mode-enabled yes|noSet
cc-mode-enabled=yesto require that users enter the key manager passphrase after a reboot. For NVE, if you setcc-mode-enabled=yes, volumes you create with thevolume createandvolume move startcommands are automatically encrypted. The- cc-mode-enabledoption is not supported in MetroCluster configurations. Thesecurity key-manager onboard enablecommand replaces thesecurity key-manager setupcommand. -
Enter a passphrase between 32 and 256 characters, or for “cc-mode”, a passphrase between 64 and 256 characters.
If the specified “cc-mode” passphrase is less than 64 characters, there is a five-second delay before the key manager setup operation displays the passphrase prompt again.
At the passphrase confirmation prompt, reenter the passphrase.
Verify that the authentication keys have been created:
security key-manager key query -key-type NSE-AKThe
security key-manager key querycommand replaces thesecurity key-manager query keycommand.Learn more about
security key-manager key queryin the ONTAP command reference. -
Optionally, you can convert plain text volumes to encrypted volumes.
volume encryption conversion startThe Onboard Key Manager must be fully configured before you convert the volumes. In a MetroCluster environment, the Onboard Key Manager must be configured on both sites.
Copy the passphrase to a secure location outside the storage system for future use.
After configuring the Onboard Key Manager passphrase, manually back up the information to a secure location outside the storage system. See Back up onboard key management information manually.
