Configure SAML authentication for remote ONTAP users
Contributors netapp-bhouser netapp-dbagwell netapp-aaron-holt netapp-mwallis netapp-thomi netapp-lenida netapp-aherbin
Beginning with ONTAP 9.3, you can configure Security Assertion Markup Language (SAML) authentication for web services. When SAML authentication is configured and enabled, users are authenticated by an external Identity Provider (IdP) instead of the directory service providers such as Active Directory and LDAP. When SAML authentication is disabled, the configured directory service providers such as Active Directory and LDAP are used for authentication.
Enable SAML authentication
To enable SAML authentication with System Manager or with the CLI, perform the following steps. If your cluster is running ONTAP 9.7 or earlier, the System Manager steps you need to follow are different. Refer to the System Manager online help available on your system.
Note After you enable SAML authentication, only remote users configured for SAML authentication can access the System Manager GUI. Local users cannot access the System Manager GUI after SAML authentication is enabled.
Workflow of the task to set up multifactor authentication with SAML
About this task
  • SAML authentication applies only to the ONTAP http and ontapi applications.
    The http and ontapi applications are used by the following web services: Service Processor Infrastructure, ONTAP APIs, and System Manager.
  • SAML authentication is applicable only for accessing the admin SVM.
  • Beginning with ONTAP 9.17.1, IdP-provided group information can be mapped to ONTAP roles. This allows you to assign roles to users based on groups that are defined in the IdP. For more information, see Working with OAuth 2.0 or SAML IdP groups in ONTAP.
The following IdPs have been validated with System Manager:
  • Microsoft Entra ID (validated with ONTAP 9.17.1 and later)
  • Active Directory Federation Services
  • Cisco Duo (validated with the following ONTAP versions:)
    • 9.7P21 and later 9.7 releases (refer to the System Manager Classic documentation)
    • 9.8P17 and later 9.8 patch releases
    • 9.9.1P13 and later 9.9.1 patch releases
    • 9.10.1P9 and later 9.10.1 patch releases
    • 9.11.1P4 and later 9.11.1 patch releases
    • 9.12.1 and later releases
  • Shibboleth
Before you begin
  • The IdP that you plan to use for remote authentication must be configured. You must have the URI of the IdP. The IdP URI is the web address that ONTAP sends authentication requests to and receive responses from.
  • Port 443 must be open between the ONTAP cluster and the IdP.
  • The ONTAP cluster and the IdP must each be able to ping the other's fully qualified domain name. Ensure DNS is properly configured and the cluster certificate is not expired.
  • If needed, add the IdP's trusted certificate authority (CA) to ONTAP. You can manage ONTAP certificates with System Manager. You might need to configure the ONTAP cluster certificate in the IdP.
  • You must be able to access the ONTAP cluster's Service Processor (SP) console. If SAML is misconfigured, you will need to disable it from the SP console.
  • If you are using Entra ID (validated beginning with ONTAP 9.17.1), you must configure Entra ID with the ONTAP metadata before creating the ONTAP SAML configuration. Entra ID will not provide the IdP URI until it is configured with the ONTAP metadata. The IdP URI is required to create the ONTAP SAML configuration.
    • If you are using System Manager to configure SAML, leave the IdP URI field blank until System Manager provides the ONTAP metadata. Configure Entra ID with the ONTAP metadata, and then copy the IdP URI into System Manager before enabling the SAML configuration.
    • If you are using the ONTAP CLI to configure SAML, you must generate the ONTAP metadata before enabling the ONTAP SAML configuration. You can generate the ONTAP metadata file with the following command:
      security saml-sp default-metadata create -sp-host <ontap_host_name>
      ontap_host_name is the host name or IP address of the SAML service provider host, which in this case is the ONTAP system. By default, the cluster-management IP address is used. You can optionally provide the ONTAP server certificate information. By default, the ONTAP web server certificate information is used.
      Configure Entra ID with the provided metadata. You must configure Entra ID before creating the ONTAP SAML configuration. After Entra is configured, proceed with the below CLI procedure.
    • You cannot generate the ONTAP metadata for Entra ID until all nodes in the cluster are on version 9.17.1.
Steps
Perform the following steps depending on your environment:
System Manager
  1. Click Cluster > Settings.
  2. Next to SAML Authentication, click Actions icon.
  3. Ensure there is a check in the Enable SAML Authentication checkbox.
  4. Enter the URL of the IdP URI (including "https://"). If you are using Entra ID, skip this step.
  5. Modify the host system address, if needed. This is the address that the IdP will direct to after authentication. The default is the cluster-management IP address.
  6. Ensure the correct certificate is being used:
    • If your system was mapped with only one certificate with type "server", then that certificate is considered the default and it isn't displayed.
    • If your system was mapped with multiple certificates as type "server", then one of the certificates is displayed. To select a different certificate, click Change.
  7. Click Save. A confirmation window displays the metadata information, which has been automatically copied to your clipboard.
  8. Go to the IdP system you specified and copy the metadata from your clipboard to update the system metadata. If you are using Entra ID, copy the IdP URI into ONTAP after you have configured Entra ID with the system metadata.
  9. Return to the confirmation window (in System Manager) and check the checkbox I have configured the IdP with the host URI or metadata.
  10. Click Logout to enable SAML-based authentication. The IdP system will display an authentication screen.
  11. In the IdP sign-on page, enter your SAML-based credentials. After your credentials are verified, you will be directed to the System Manager home page.
    Ensure that each remote user who needs access has a SAML login method. If a SAML login method was not created automatically, create one for the user from the ONTAP CLI:
    security login create -user-or-group-name <user_name> -application http -authentication-method saml -vserver <svm_name>
CLI
  1. Create a SAML configuration so that ONTAP can access the IdP metadata:
    security saml-sp create -idp-uri <idp_uri> -sp-host <ontap_host_name>
    idp_uri is the FTP or HTTP address of the IdP host from where the IdP metadata can be downloaded.
    Note Some URLs include the question mark (?) character. The question mark activates the ONTAP command line active help. In order to enter a URL with a question mark, you need to first disable active help with the command set -active-help false. Active help can later be re-enabled with the command set -active-help true. Learn more in the ONTAP command reference.
    ontap_host_name is the host name or IP address of the SAML service provider host, which in this case is the ONTAP system. By default, the IP address of the cluster-management LIF is used.
    cluster_12::> security saml-sp create -idp-uri https://example.url.net/idp/shibboleth
    Warning: This restarts the web server. Any HTTP/S connections that are active
             will be disrupted.
    Do you want to continue? {y|n}: y
    [Job 179] Job succeeded: Access the SAML SP metadata using the URL:
    https://10.0.0.1/saml-sp/Metadata
    Configure the IdP and ONTAP users for the same directory server domain to ensure that users are the same for different authentication methods. See the "security login show" command for the ONTAP user configuration.
    The URL to access the ONTAP host metadata is displayed.
  2. From the IdP host, configure the IdP with the ONTAP host metadata. If you are using Entra ID, you have already completed this step.
  3. Once the IdP is configured, enable SAML configuration:
    security saml-sp modify -is-enabled true
    Any existing user that accesses the http or ontapi application is automatically configured for SAML authentication.
  4. If you want to create users for the http or ontapi application after SAML is configured, specify SAML as the authentication method for the new users. Prior to ONTAP 9.17.1, a SAML login is automatically created for existing http or ontapi users when SAML is enabled. New users must be configured for SAML. Beginning with ONTAP 9.17.1, all users created with password, domain, or nsswitch authentication methods are automatically authenticated against the IdP when SAML is enabled.
    1. Create a login method for new users with SAML authentication. The user_name must match the username configured in the IdP:
      Note The user_name value is case-sensitive. Unless you are using Entra ID, include only the user name, and do not include any portion of the domain. If you are using Entra ID, you can create the user name with the domain, for example user_name@domain.com.
      security login create -user-or-group-name <user_name> -application [http | ontapi] -authentication-method saml -vserver <svm_name>
      Example:
      cluster_12::> security login create -user-or-group-name admin1 -application http -authentication-method saml -vserver cluster_12
    2. Verify that the user entry is created:
      security login show
      Example:
      cluster_12::> security login show
      Vserver: cluster_12
        Second
      User/Group                 Authentication                 Acct   Authentication
      Name           Application Method        Role Name        Locked Method
      admin          console     password      admin            no     none
      admin          http        password      admin            no     none
      admin          http        saml          admin            -      none
      admin          ontapi      password      admin            no     none
      admin          ontapi      saml          admin            -      none
      admin          service-processor
      admin          ssh         password      admin            no     none
      admin1         http        password      backup           no     none
      admin1         http        saml          backup           -      none
      Learn more about security login show in the ONTAP command reference.
Disable SAML authentication
You can disable SAML authentication when you want to stop authenticating remote System Manager users with an external Identity Provider (IdP). When SAML authentication is disabled, local user authentication or the configured directory service providers such as Active Directory and LDAP are used to authenticate users.
Example 1. Steps
System Manager
  2. Under SAML Authentication, click the Enabled toggle button.
  3. Optional: You can also click Actions icon next to SAML Authentication, and then uncheck the Enable SAML Authentication checkbox.
CLI
  1. Disable SAML authentication:
    security saml-sp modify -is-enabled false
  2. If you no longer want to use SAML authentication or if you want to modify the IdP, delete the SAML configuration:
    security saml-sp delete
Configure third-party IdP
About this task
In order to authenticate with ONTAP, you might need to change the settings for your IdP. The following sections provide configuration information for supported IdPs.
Entra ID
When configuring Entra ID, create a new application and configure SAML sign-on with the metadata provided by ONTAP. After the application is created, edit the "Attributes & Claims" section of the application SAML settings to match the following:
Setting Value
Name
urn:oid:0.9.2342.19200300.100.1.1
Namespace
Leave blank
Name format
URI
Source
Attribute
Source attribute
user.userprincipalname
If you want to use groups with Entra ID, add a group claim with the following settings:
Setting Value
Name
urn:oid:1.3.6.1.4.1.5923.1.5.1.1
Namespace
Leave blank
Source attribute
Group ID
Entra ID provides group information in UUID format. For more information on using groups with Entra ID, refer to Manage groups with UUIDs.
The App Federation Metadata URL provided in the "SAML certificate" section of the application SAML settings is the IdP URI that you will enter in ONTAP.
For information on configuring Entra ID multifactor authentication, refer to Plan a Microsoft Entra multifactor authentication deployment.
For more information, refer to the Entra ID documentation.
When configuring Active Directory Federation Services (AD FS), you must add a new claims-aware Relying Party Trust with the service provider metadata provided by ONTAP. Once the Relying Party Trust is created, add the following claim rules to the Relying Party Trust's Claim Issuance Policy using the "Send LDAP Attributes as Claims" template:
Attribute store LDAP attribute Outgoing claim type
Active Directory
SAM-account-name
Name ID
Active Directory
SAM-account-name
Active Directory
Name Format
urn:oasis:names:tc:SAML:2.0:attrname-format:uri
Active Directory
Token groups - Qualified by Domain Name
Active Directory
sAMAccountName
urn:oid:1.2.840.113556.1.4.221
AD FS provides group information in name format. For more information on using groups with AD FS, refer to Manage groups with names.
For more information, refer to the AD FS documentation.
Cisco Duo
Refer to the Cisco Duo documentation for configuration information.
Shibboleth
Prior to configuring the Shibboleth IdP, you must have configured an LDAP server.
When enabling SAML on ONTAP, save the provided host metadata XML. On the host where Shibboleth is installed, replace the contents of metadata/sp-metadata.xml with the host metadata XML within the Shibboleth IdP home directory.
For more information, refer to Shibboleth.
Troubleshoot issues with SAML configuration
If configuring Security Assertion Markup Language (SAML) authentication fails, you can manually repair each node on which the SAML configuration failed and recover from the failure. During the repair process, the web server is restarted and any active HTTP connections or HTTPS connections are disrupted.
About this task
When you configure SAML authentication, ONTAP applies SAML configuration on a per-node basis. When you enable SAML authentication, ONTAP automatically tries to repair each node if there are configuration issues. If there are issues with SAML configuration on any node, you can disable SAML authentication and then reenable SAML authentication. There can be situations when SAML configuration fails to apply on one or more nodes even after you reenable SAML authentication. You can identify the node on which SAML configuration has failed and then manually repair that node.
Steps
  1. Log in to the advanced privilege level:
    set -privilege advanced
  2. Identify the node on which SAML configuration failed:
    security saml-sp status show -instance
    Example:
    cluster_12::*> security saml-sp status show -instance
                             Node: node1
                    Update Status: config-success
                   Database Epoch: 9
       Database Transaction Count: 997
                       Error Text:
    SAML Service Provider Enabled: false
            ID of SAML Config Job: 179
                             Node: node2
                    Update Status: config-failed
                   Database Epoch: 9
                       Error Text: SAML job failed, Reason: Internal error. Failed to receive the SAML IDP Metadata file.
            ID of SAML Config Job: 180
    2 entries were displayed.
    Learn more about security saml-sp status show in the ONTAP command reference.
  3. Repair the SAML configuration on the failed node:
    security saml-sp repair -node <node_name>
    Example:
    cluster_12::*> security saml-sp repair -node node2
             will be disrupted.
    [Job 181] Job is running.
    [Job 181] Job success.
    The web server is restarted and any active HTTP connections or HTTPS connections are disrupted.
    Learn more about security saml-sp repair in the ONTAP command reference.
  4. Verify that SAML is successfully configured on all of the nodes:
    Example:
                             Node: node1
                   Database Epoch: 9
                       Error Text:
                             Node: node2
                   Database Epoch: 9
                       Error Text:
