Commands for managing ONTAP AutoSupport
You use the system node autosupport commands to change or view AutoSupport configuration, display information about previous AutoSupport messages, and send, resend or cancel an AutoSupport message.
Configure AutoSupport
| If you want to… | Use this command… |
Control whether any AutoSupport messages are sent |
Control whether AutoSupport messages are sent to technical support |
Set up AutoSupport or modify the configuration of AutoSupport |
Enable and disable AutoSupport messages to your internal support organization for individual trigger events, and specify additional subsystem reports to include in messages sent in response to individual trigger events |
Display information about the AutoSupport configuration
Display the AutoSupport configuration |
View a summary of all addresses and URLs that receive AutoSupport messages |
Display which AutoSupport messages are sent to your internal support organization for individual trigger events |
Display status of AutoSupport configuration as well as delivery to various destinations |
Display detailed status of AutoSupport configuration as well as delivery to various destinations |
Display information about past AutoSupport messages
Display information about one or more of the 50 most recent AutoSupport messages |
Display information about recent AutoSupport messages generated to upload core dump or performance archive files to the technical support site or a specified URI |
View the information in the AutoSupport messages including the name and size of each file collected for the message along with any errors |
Send, resend, or cancel AutoSupport messages
| If you want to… | Use this command… | ||
Retransmit a locally stored AutoSupport message, identified by its AutoSupport sequence number
Generate and send an AutoSupport message—for example, for testing purposes |
Cancel an AutoSupport message |
Learn more about system node autosupport in the ONTAP command reference.
