ONTAP commands for BMC management
These ONTAP commands are supported on the Baseboard Management Controller (BMC).
The BMC uses some of the same commands as the Service Processor (SP). The following SP commands are supported on the BMC.
| If you want to… | Use this command |
Display the BMC information |
Display/modify the BMC network configuration |
Reset the BMC |
Display/modify the details of the currently installed BMC firmware image |
Update BMC firmware |
Display the status for the latest BMC firmware update |
Enable the automatic network configuration for the BMC to use an IPv4 or IPv6 address on the specified subnet |
Disable the automatic network configuration for an IPv4 or IPv6 address on the subnet specified for the BMC |
Display the BMC automatic network configuration |
For commands that are not supported by the BMC firmware, the following error message is returned.
::> Error: Command not supported on this platform.
