Move an encrypted volume in ONTAP
You can use the volume move start command to move an encrypted volume. The moved volume can reside on the same aggregate or a different aggregate.
The move will fail if the destination node or destination volume does not support volume encryption.
The -encrypt-destination option for volume move start defaults to true for encrypted volumes. The requirement to specify you do not want the destination volume encrypted ensures that you do not inadvertently unencrypt the data on the volume.
You must be a cluster administrator to perform this task.
Move an existing encrypted volume and leave the data on the volume encrypted:
volume move start -vserver SVM_name -volume volume_name -destination-aggregate aggregate_nameLearn more about
volume move startin the ONTAP command reference.The following command moves an existing volume named
vol1to the destination aggregateaggr3and leaves the data on the volume encrypted:cluster1::> volume move start -vserver vs1 -volume vol1 -destination-aggregate aggr3
Verify that the volume is enabled for encryption:
volume show -is-encrypted trueLearn more about
volume showin the ONTAP command reference.The following command displays the encrypted volumes on
cluster1:cluster1::> volume show -is-encrypted true Vserver Volume Aggregate State Type Size Available Used ------- ------ --------- ----- ---- ----- --------- ---- vs1 vol1 aggr3 online RW 200GB 160.0GB 20%
