Create ONTAP NAS volumes without specific junction points
You can create a data volume without specifying a junction point. The resultant volume is not automatically mounted, and is not available to configure for NAS access. You must mount the volume before you can configure SMB shares or NFS exports for that volume.
The aggregate in which you want to create the volume must already exist.
Beginning with ONTAP 9.13.1, you can create volumes with capacity analytics and Activity Tracking enabled. To enable capacity or Activity Tracking, issue the
volume createcommand with-analytics-stateor-activity-tracking-stateset toon.To learn more about capacity analytics and Activity Tracking, see Enable File System Analytics. Learn more about
volume createin the ONTAP command reference.
Create the volume without a junction point by using the following command:
volume create -vserver vserver_name -volume volume_name -aggregate aggregate_name -size {integer[KB|MB|GB|TB|PB]} -security-style {ntfs|unix|mixed}Specifying a volume security style is optional. If you do not specify a security style, ONTAP creates the volume with the same security style that is applied to the root volume of the storage virtual machine (SVM). However, the root volume's security style might not be the security style you want applied to the data volume. The recommendation is to specify the security style when you create the volume to minimize difficult-to-troubleshoot file-access issues.
There are many optional parameters that you can use to customize a data volume. Learn more about
volume createin the ONTAP command reference. -
Verify that the volume was created without a junction point:
volume show -vserver vserver_name -volume volume_name -junction
The following example creates a volume named “sales” located on SVM vs1 that is not mounted at a junction point:
cluster1::> volume create -vserver vs1 -volume sales -aggregate aggr3 -size 20GB
[Job 3406] Job succeeded: Successful
cluster1::> volume show -vserver vs1 -junction
Junction Junction
Vserver Volume Active Junction Path Path Source
vs1 data true /data RW_volume
vs1 home4 true /eng/home RW_volume
vs1 vs1_root - / -
vs1 sales - - -
