Learn about the ONTAP command-line interface
The ONTAP command-line interface (CLI) provides a command-based view of the management interface. You enter commands at the storage system prompt, and command results are displayed in text.
The CLI command prompt is represented as cluster_name::>.
If you set the privilege level (that is, the -privilege parameter of the set command) to advanced, the prompt includes an asterisk (*), for example:
cluster_name::*>
Learn more about set in the ONTAP command reference.
