ONTAP commands for managing NFS LDAP client schema templates
There are specific ONTAP commands for managing LDAP client schema templates.
SVM administrators cannot modify or delete LDAP client schemas that were created by cluster administrators. |
If you want to… |
Use this command… |
Copy an existing LDAP schema template |
Display LDAP schema templates |
Modify an LDAP schema template |
Delete an LDAP schema template |
Learn more about vserver services name-service ldap client schema in the ONTAP command reference.
