Determine whether ONTAP SMB clients are connected using NetBIOS aliases
You can determine whether SMB clients are connected using NetBIOS aliases, and if so, which NetBIOS alias is used to make the connection. This can be useful when troubleshooting connection issues.
You must use the -instance parameter to display the NetBIOS alias (if any) associated with an SMB connection. If the CIFS server name or an IP address is used to make the SMB connection, the output for the NetBIOS Name field is - (hyphen).
Perform the desired action:
If you want to display NetBIOS information for… Enter… SMB connections
vserver cifs session show -instanceConnections using a specified NetBIOS alias:
vserver cifs session show -instance -netbios-name netbios_nameThe following example displays information about the NetBIOS alias used to make the SMB connection with session ID 1:
vserver cifs session show -session-id 1 -instanceNode: node1 Vserver: vs1 Session ID: 1 Connection ID: 127834 Incoming Data LIF IP Address: 10.1.1.25 Workstation: 10.2.2.50 Authentication Mechanism: NTLMv2 Windows User: EXAMPLE\user1 UNIX User: user1 Open Shares: 2 Open Files: 2 Open Other: 0 Connected Time: 1d 1h 10m 5s Idle Time: 22s Protocol Version: SMB3 Continuously Available: No Is Session Signed: true User Authenticated as: domain-user NetBIOS Name: ALIAS1 SMB Encryption Status: Unencrypted
