Add ONTAP local tiers automatically
If the best-practice recommendation that ONTAP provides for automatically adding a local tier is appropriate in your environment, you can accept the recommendation and let ONTAP add the local tier.
Prior to ONTAP 9.7, System Manager uses the term aggregate to describe a local tier. Regardless of your ONTAP version, the ONTAP CLI uses the term aggregate. To learn more about local tiers, see Disks and local tiers. |
Disks must be owned by a node before they can be used in a local tier. If your cluster is not configured to use automatic disk ownership assignment, you must assign ownership manually.
Learn more about the commands described in this procedure in the ONTAP command reference.
In System Manager, click Storage > Tiers.
From the Tiers page, click
to create a new local tier:The Add Local Tier page shows the recommended number of local tiers that can be created on the nodes and the usable storage available.
Click Recommended details to view the configuration recommended by System Manager.
System Manager displays the following information beginning with ONTAP 9.8:
Local tier name (you can edit the local tier name beginning with ONTAP 9.10.1)
Node name
Usable size
Type of storage
Beginning with ONTAP 9.10.1, additional information is displayed:
Disks: showing the number, size, and type of the disks
Layout: showing the RAID group layout, including which disks are parity or data and which slots are unused.
Spare disks: showing the node name, the number and size of spare disks, and the type of storage.
Perform one of the following steps:
If you want to…
Then do this…
Accept the recommendations from System Manager.
Manually configure the local tiers and not use the recommendations from System Manager.
Proceed to Add a local tier manually:
For ONTAP 9.10.1 and earlier, follow the steps to use the CLI.
Beginning with ONTAP 9.11.1, follow the steps to use System Manager.
(Optional): If the Onboard Key Manager has been installed, you can configure it for encryption. Check the Configure Onboard Key Manager for encryption check box.
Enter a passphrase.
Enter the passphrase again to confirm it.
Save the passphrase for future use in case the system needs to be recovered.
Back up the key database for future use.
Click Save to create the local tier and add it to your storage solution.
You run the storage aggregate auto-provision command to generate local tier layout recommendations. You can then create local tiers after reviewing and approving ONTAP recommendations.
The default summary generated with the storage aggregate auto-provision command lists the recommended local tiers to be created, including names and usable size. You can view the list and determine whether you want to create the recommended local tiers when prompted.
You can also display a detailed summary by using the -verbose option, which displays the following reports:
Per node summary of new local tiers to create, discovered spares, and remaining spare disks and partitions after local tier creation
New data local tiers to create with counts of disks and partitions to be used
RAID group layout showing how spare disks and partitions will be used in new data local tiers to be created
Details about spare disks and partitions remaining after local tier creation
If you are familiar with the auto-provision method and your environment is correctly prepared, you can use the -skip-confirmation option to create the recommended local tier without display and confirmation. The storage aggregate auto-provision command is not affected by the CLI session -confirmations setting.
Learn more about storage aggregate auto-provision in the ONTAP command reference.
Run the
storage aggregate auto-provisioncommand with the desired display options.-
no options: Display standard summary
-verboseoption: Display detailed summary -
-skip-confirmationoption: Create recommended local tiers without display or confirmation
If you want to…
Then do this…
Accept the recommendations from ONTAP.
Review the display of recommended local tiers, and then respond to the prompt to create the recommended local tiers.
myA400-44556677::> storage aggregate auto-provision Node New Data Aggregate Usable Size ------------------ ---------------------------- ------------ myA400-364 myA400_364_SSD_1 3.29TB myA400-363 myA400_363_SSD_1 1.46TB ------------------ ---------------------------- ------------ Total: 2 new data aggregates 4.75TB Do you want to create recommended aggregates? {y|n}: y Info: Aggregate auto provision has started. Use the "storage aggregate show-auto-provision-progress" command to track the progress. myA400-44556677::>Manually configure the local tiers and not use the recommendations from ONTAP.
Proceed to Add a local tier manually.
