Configure switches for FCoE
You must configure your switches for FCoE before your FC service can run over the existing Ethernet infrastructure.
Your SAN configuration must be supported.
For more information about supported configurations, see the NetApp Interoperability Matrix Tool.
A Unified Target Adapter (UTA) must be installed on your storage system.
If you are using a UTA2, it must be set to
cnamode. -
A converged network adapter (CNA) must be installed on your host.
Use your switch documentation to configure your switches for FCoE.
Verify that the DCB settings for each node in the cluster have been correctly configured.
run -node node1 -command dcb showDCB settings are configured on the switch. Consult your switch documentation if the settings are incorrect.
Verify that the FCoE login is working when the FC target port online status is
true.fcp adapter show -fields node,adapter,status,state,speed,fabric-established,physical-protocolIf the FC target port online status is
false, consult your switch documentation.
