Learn about requirements for using roaming ONTAP SMB profiles
Before you can use Microsoft's roaming profiles with your CIFS server, you need to know which versions of ONTAP and SMB and which Windows clients support the feature.
ONTAP version requirements
ONTAP support roaming profiles.
SMB protocol version requirements
For storage virtual machine (SVM), ONTAP supports roaming profiles on all versions of SMB.
Windows client requirements
Before a user can use the roaming profiles, the Windows client must support the feature.
For the latest information about which Windows clients support roaming profiles, see the Interoperability Matrix.
