Convert an ONTAP SnapMirror volume relationship to an SVM relationship
You can convert replication relationships between volumes to a replication relationship between the storage virtual machines (SVMs) that own the volumes, provided that each volume on the source (except the root volume) is being replicated, and each volume on the source (including the root volume) has the same name as the volume on the destination.
Use the volume rename command when the SnapMirror relationship is idle to rename destination volumes if necessary. Learn more about volume rename in the ONTAP command reference.
From the destination SVM or the destination cluster, run the following command to resync the source and destination volumes:
snapmirror resync -source-path <SVM:volume> -destination-path <SVM:volume> -type DP|XDP -policy <policy>Learn more about
snapmirror resyncin the ONTAP command reference.Although resync does not require a baseline transfer, it can be time-consuming. You might want to run the resync in off-peak hours.
The following example resyncs the relationship between the source volume
volAonsvm1and the destination volumevolAonsvm_backup:cluster_dst::> snapmirror resync -source-path svm1:volA -destination-path svm_backup:volA
Create an SVM replication relationship between the source and destination SVMs, as described in Replicating SVM configurations.
You must use the
-identity-preserve trueoption of thesnapmirror createcommand when you create your replication relationship.Learn more about
snapmirror createin the ONTAP command reference. -
Stop the destination SVM:
vserver stop -vserver SVMLearn more about
vserver stopin the ONTAP command reference.The following example stops the destination SVM
svm_backup:cluster_dst::> vserver stop svm_backup
From the destination SVM or the destination cluster, run the following command to resync the source and destination SVMs:
snapmirror resync -source-path <SVM>: -destination-path <SVM>: -type DP|XDP -policy <policy>You must enter a colon (:) after the SVM name in the
-source-pathand-destination-pathoptions. See the example below.Although resync does not require a baseline transfer, it can be time-consuming. You might want to run the resync in off-peak hours.
The following example resyncs the relationship between the source SVM
svm1and the destination SVMsvm_backup:cluster_dst::> snapmirror resync -source-path svm1: -destination-path svm_backup:
