View adapter settings
You can use specific commands to view information about your FC/UTA adapters.
FC target adapter
Step
Use the
network fcp adapter showcommand to display adapter information:network fcp adapter show -instance -node node1 -adapter 0aThe output displays system configuration information and adapter information for each slot that is used.
Learn more about
network fcp adapter showin the ONTAP command reference.
Unified Target Adapter (UTA) X1143A-R6
Steps
Boot your controller without the cables attached.
Run the
system hardware unified-connect showcommand to see the port configuration and modules. -
View the port information before configuring the CNA and ports.
