ONTAP commands for managing NTFS security descriptors on SMB servers
There are specific ONTAP commands for managing security descriptors. You can create, modify, delete, and display information about security descriptors.
| If you want to… | Use this command… |
Create NTFS security descriptors |
Modify existing NTFS security descriptors |
Display information about existing NTFS security descriptors |
Delete NTFS security descriptors |
Learn more about vserver security file-directory ntfs in the ONTAP command reference.
