Examples of ONTAP export policy rules that restrict or allow access over SMB
The examples show how to create export policy rules that restrict or allow access over SMB on an SVM that has export policies for SMB access enabled.
Export policies for SMB access are disabled by default. You need to configure export policy rules that restrict or allow access over SMB only if you have enabled export policies for SMB access.
Export rule for SMB access only
The following command creates an export rule on the SVM named “vs1” that has the following configuration:
Policy name: cifs1
Index number: 1
Client match: Matches only clients on the 192.168.1.0/24 network
Protocol: Only enables SMB access
Read-only access: To clients using NTLM or Kerberos authentication
Read-write access: To clients using Kerberos authentication
cluster1::> vserver export-policy rule create -vserver vs1 -policyname cifs1 ‑ruleindex 1 -protocol cifs -clientmatch 192.168.1.0/255.255.255.0 -rorule krb5,ntlm -rwrule krb5
Export rule for SMB and NFS access
The following command creates an export rule on the SVM named"` vs1`" that has the following configuration:
Policy name: cifsnfs1
Index number: 2
Client match: Matches all clients
Protocol: SMB and NFS access
Read-only access: To all clients
Read-write access: To clients using Kerberos (NFS and SMB) or NTLM authentication (SMB)
Mapping for UNIX user ID 0 (zero): Mapped to user ID 65534 (which typically maps to the user name nobody)
Suid and sgid access: Allows
cluster1::> vserver export-policy rule create -vserver vs1 -policyname cifsnfs1 ‑ruleindex 2 -protocol cifs,nfs -clientmatch 0.0.0.0/0 -rorule any -rwrule krb5,ntlm -anon 65534 -allow-suid true
Export rule for SMB access using NTLM only
Policy name: ntlm1
Index number: 1
Read-only access: Only to clients using NTLM
Read-write access: Only to clients using NTLM
If you configure the read-only option or the read-write option for NTLM-only access, you must use IP address-based entries in the client match option. Otherwise, you receive |
cluster1::> vserver export-policy rule create -vserver vs1 -policyname ntlm1 ‑ruleindex 1 -protocol cifs -clientmatch 0.0.0.0/0 -rorule ntlm -rwrule ntlm
