Types of data that the dump engine restores
PDF of this doc site
Cluster administration
Volume administration
Logical storage management with the CLI
NAS storage management
Configure NFS with the CLI
Manage NFS with the CLI
Manage SMB with the CLI
Manage file access using SMB
Security and data encryption
Data protection and disaster recovery
Creating your file...
When a disaster or controller disruption occurs, the dump engine provides multiple methods for you to recover all of the data that you backed up, from single files, to file attributes, to entire directories. Knowing the types of data that dump engine can restore and when to use which method of recovery can help minimize downtime.
You can restore data to an online mapped LUN. However, host applications cannot access this LUN until the restore operation is complete. After the restore operation is complete, the host cache of the LUN data should be flushed to provide coherency with the restored data.
The dump engine can recover the following data:
Contents of files and directories
UNIX file permissions
ACLs
If you restore a file that has only UNIX file permissions to an NTFS qtree or volume, the file has no Windows NT ACLs. The storage system uses only the UNIX file permissions on this file until you create a Windows NT ACL on it.
If you restore ACLs backed up from storage systems running Data ONTAP 8.2 to storage systems running Data ONTAP 8.1.x and earlier that have an ACE limit lower than 1,024, a default ACL is restored.
Qtree information
Qtree information is used only if a qtree is restored to the root of a volume. Qtree information is not used if a qtree is restored to a lower directory, such as
/vs1/vol1/subdir/lowerdir
, and it ceases to be a qtree. -
All other file and directory attributes
Windows NT streams
LUNs
A LUN must be restored to a volume level or a qtree level for it to remain as a LUN.
If it is restored to a directory, it is restored as a file because it does not contain any valid metadata.
A 7-Mode LUN is restored as a LUN on an ONTAP volume.
A 7-Mode volume can be restored to an ONTAP volume.
VM-aligned files restored to a destination volume inherit the VM-align properties of the destination volume.
The destination volume for a restore operation might have files with mandatory or advisory locks.
While performing restore operation to such a destination volume, the dump engine ignores these locks.
