Learn about ONTAP SnapMirror synchronous disaster recovery
Contributors netapp-lenida netapp-aaron-holt netapp-ahibbard netapp-dbagwell netapp-aherbin netapp-thomi netapp-revathid
Beginning with ONTAP 9.5, SnapMirror synchronous (SM-S) technology is supported on all FAS and AFF platforms that have at least 16 GB of memory and on all ONTAP Select platforms. SnapMirror synchronous technology is a per-node, licensed feature that provides synchronous data replication at the volume level.
This functionality addresses the regulatory and national mandates for synchronous replication in financial, healthcare, and other regulated industries where zero data loss is required.
SnapMirror synchronous operations allowed
The limit on the number of SnapMirror synchronous replication operations per HA pair depends on the controller model.
The following table lists the number of SnapMirror synchronous operations that are allowed per HA pair according to platform type and ONTAP release.
Platform
ONTAP 9.20.1 and later
ONTAP 9.11.1 through ONTAP 9.19.1
ONTAP 9.10.1
ONTAP 9.9.1
Releases earlier than ONTAP 9.9.1
AFF
600
400
200
160
80
ASA
400
400
200
160
80
FAS
80
80
80
80
40
ONTAP Select
40
40
40
40
20
Supported features
The following table indicates the features supported with SnapMirror synchronous and the ONTAP releases in which support is available.
Feature
Release first supported
Additional information
Antivirus on the primary volume of the SnapMirror synchronous relationship
ONTAP 9.6
Application-created snapshot replication
ONTAP 9.7
If a snapshot is tagged with the appropriate label at the time of the snapshot create operation, using the CLI or the ONTAP API, SnapMirror synchronous replicates the snapshots, both user created or those created with external scripts, after quiescing the applications. Beginning with ONTAP 9.14.1, the label requirement for replication of application-created snapshots no longer exists. For more information about replicating application-created snapshots, see the NetApp Knowledge Base: How to replicate application created snapshots with SnapMirror synchronous.
Autonomous ransomware protection
ONTAP 9.19.1
Clone auto delete
ONTAP 9.6
FabricPool aggregates with tiering policy of None, Snapshot, or Auto are supported with SnapMirror synchronous source and destination.
ONTAP 9.5
The destination volume in a FabricPool aggregate cannot be set to All tiering policy.
FC
ONTAP 9.5
Over all networks for which latency does not exceed 10ms
FC-NVMe
ONTAP 9.7
File clones
ONTAP 9.7
FPolicy on the primary volume of the SnapMirror synchronous relationship
ONTAP 9.6
Hard and soft quotas on the primary volume of the SnapMirror synchronous relationship
ONTAP 9.6
The quota rules are not replicated to the destination; therefore, the quota database is not replicated to the destination.
Intra-cluster synchronous relationships
ONTAP 9.14.1
High availability is provided when source and destination volumes are placed on different HA pairs.
If the entire cluster goes down, access to volumes will not be possible until the cluster is recovered.
Intra-cluster SnapMirror synchronous relationships will contribute to the overall limit of simultaneous relationships per HA pair.
iSCSI
ONTAP 9.5
LUN clones and NVMe namespace clones
ONTAP 9.7
LUN clones backed by application-created snapshots
ONTAP 9.7
Mixed protocol access (NFS v3 and SMB)
ONTAP 9.6
NDMP/NDMP restore
ONTAP 9.13.1
Both the source and destination cluster must be running ONTAP 9.13.1 or later to perform dump- or SMTape-based NDMP backup of SnapMirror synchronous volumes. NDMP restores, either dump- or SMTape-based, are not supported to destination volumes in a SnapMirror active sync or SnapMirror synchronous relationship.
Non-disruptive SnapMirror synchronous operations (NDO) on AFF/ASA platforms, only.
ONTAP 9.12.1
Support for non-disruptive operations enables you to perform many common maintenance tasks without scheduling down time. Operations supported include takeover and giveback, and volume move, provided that a single node is surviving among each of the two clusters.
NFS v4.2
ONTAP 9.10.1
NFS v4.0
ONTAP 9.6
NFS v4.1
ONTAP 9.6
NVMe/TCP
9.10.1
Removal of high metadata operation frequency limitation
ONTAP 9.6
Replication of snapshot management operations
ONTAP 9.19.1
Beginning with ONTAP 9.19.1, the snapshot management operations snapshot delete, snapshot rename, and snapshot modify are replicated to secondary cluster.
Scheduled snapshot replication
ONTAP 9.19.1
Beginning with ONTAP 9.19.1, you can enable replication of scheduled snapshots using a SnapMirror policy. In releases earlier than ONTAP 9.19.1, scheduled snapshots created using a snapshot policy are not replicated.
Security for sensitive data in-transit using TLS 1.2 encryption
ONTAP 9.6
Single file and partial file restore
ONTAP 9.13.1
SMB 2.0 or later
ONTAP 9.6
SnapMirror synchronous mirror-mirror cascade
ONTAP 9.6
The relationship from the destination volume of the SnapMirror synchronous relationship must be an SnapMirror asynchronous relationship.
SVM disaster recovery
ONTAP 9.6
  • A SnapMirror synchronous source can also be a SVM disaster recovery source, for example, a fan-out configuration with SnapMirror synchronous as one leg and SVM disaster recovery as the other.
  • A SnapMirror synchronous source cannot be an SVM disaster recovery destination because SnapMirror synchronous does not support cascading a data protection source.
    You must release the synchronous relationship before performing an SVM disaster recovery flip resync in the destination cluster.
  • A SnapMirror synchronous destination cannot be an SVM disaster recovery source because SVM disaster recovery does not support replication of DP volumes.
    A flip resync of the synchronous source would result in the SVM disaster recovery excluding the DP volume in the destination cluster.
Tamperproof snapshots
ONTAP 9.19.1
You can specify the expiry time only during snapshot creation. You cannot set or extend the expiry time on existing snapshots.
Tape-based restore to the source volume
ONTAP 9.13.1
Timestamp parity between source and destination volumes for NAS
ONTAP 9.6
If you have upgraded from ONTAP 9.5 to ONTAP 9.6, the timestamp is replicated only for any new and modified files in the source volume. The timestamp of existing files in the source volume is not synchronized.
Unsupported features
The following features are not supported with SnapMirror synchronous relationships:
  • Consistency groups
  • DP_Optimized (DPO) systems
  • FlexGroup volumes
  • FlexCache volumes
  • Global throttling
  • In a fan-out configuration, only one relationship can be a SnapMirror synchronous relationship; all the other relationships from the source volume must be SnapMirror asynchronous relationships.
  • LUN move
  • MetroCluster configurations
  • Mixed SAN and NVMe access
    LUNs and NVMe namespaces are not supported on the same volume or SVM.
  • SnapCenter
  • SnapLock volumes
  • Dump or SMTape-based NDMP restore to destination volumes in a SnapMirror active sync or SnapMirror synchronous relationship
  • Throughput floor (QoS Min) for source volumes
  • Volume SnapRestore
  • VVol
Modes of operation
SnapMirror synchronous has two modes of operation based on the type of the SnapMirror policy used:
  • Sync mode
    In Sync mode, application I/O operations are sent in parallel to the primary and secondary
    storage systems. If the write to the secondary storage is not completed for any reason, the application is allowed to continue writing to the primary storage. When the error condition is corrected, SnapMirror synchronous technology automatically resynchronizes with the secondary storage and resumes replicating from primary storage to secondary storage in synchronous mode.
    In Sync mode, RPO=0 and RTO is very low until a secondary replication failure occurs at which time RPO and RTO become indeterminate, but equal the time to repair the issue that caused secondary replication to fail and for the resync to complete.
  • StrictSync mode
    SnapMirror synchronous can optionally operate in StrictSync mode. If the write to the secondary storage is not completed for any reason, the application I/O fails, thereby ensuring that the primary and secondary storage are identical. Application I/O to the primary resumes only after the SnapMirror relationship returns to the InSync status. If the primary storage fails, application I/O can be resumed on the secondary storage, after failover, with no loss of data.
    In StrictSync mode RPO is always zero, and RTO is very low.
Relationship status
The status of a SnapMirror synchronous relationship is always in the InSync status during normal operation. If the SnapMirror transfer fails for any reason, the destination is not in sync with the source and can go to the OutofSync status.
For SnapMirror synchronous relationships, the system automatically checks the relationship status (InSync or OutofSync) at a fixed interval. If the relationship status is OutofSync, ONTAP automatically triggers the auto resync process to bring back the relationship to the InSync status. Auto resync is triggered only if the transfer fails due to any operation, such as unplanned storage failover at source or destination or a network outage. User-initiated operations such as snapmirror quiesce and snapmirror break do not trigger auto resync.
If the relationship status becomes OutofSync for a SnapMirror synchronous relationship in the StrictSync mode, all I/O operations to the primary volume are stopped. The OutofSync state for SnapMirror synchronous relationship in the Sync mode is not disruptive to the primary and I/O operations are allowed on the primary volume.
Beginning with ONTAP 9.19.1, you can use the SnapMirror policy parameter -sync-snapshot-replication-mode in advanced privilege mode to replicate scheduled snapshots to the SnapMirror destination. Replicating scheduled snapshots provides symmetry between the primary and secondary volumes in a SnapsMirror synchronous relationship.
Prerequisites
  • You must be a cluster or SVM administrator
  • You must be in advanced privilege mode
  • You must configure a user-defined SnapMirror policy that uses the parameter -sync-snapshot-replication-mode and includes the option sched_created.
    • System-defined policies cannot be modified. You must create a new policy and reestablish the relationship.
    • User-defined policy changes require a resync (quiesce followed by resume) to take effect on existing relationships.
The parameter accepts these options:
  • none- disables replication of non-SnapMirror synchronous snapshots
  • application_created- replicates application-created snapshots
  • sched_created - replicates scheduled snapshots
  • sm_created - replicates SnapMirror asynchronous (fanout leg) created snapshots
  • A comma-separated list of types: application_created, sched_created, and sm_created.
The parameter only takes effect once the relationship status is InSync. Snapshot types not listed are stored only on the primary volume.
Beginning with ONTAP 9.19.1, snapmirror initialize replicates all snapshots to the secondary cluster, while snapmirror resync only replicates new snapshots created after the last common snapshot. During a resync operation, non-replicated snapshots tagged as primary-only when the relationship status is InSync are not replicated to the secondary cluster, and those snapshots are retained at the new secondary cluster following a flip resync operation.
Note Creating snapshots on SnapMirror synchronous volumes can increase user I/O latency. It is recommended that you use snapshot schedules with a frequency greater than 30 minutes.
