View the help information in the ONTAP SP/BMC CLI
The online help displays the SP/BMC CLI commands and options.
About this task
This task applies to both the SP and the BMC.
Steps
To display help information for the SP/BMC commands, enter the following:
To access SP help… To access BMC help… Type
helpat the SP prompt.Type
systemat the BMC prompt.The following example shows the SP CLI online help.
SP> help date - print date and time exit - exit from the SP command line interface events - print system events and event information help - print command help priv - show and set user mode sp - commands to control the SP system - commands to control the system version - print SP version
The following example shows the BMC CLI online help.
BMC> system system acp - acp related commands system battery - battery related commands system console - connect to the system console system core - dump the system core and reset system cpld - cpld commands system log - print system console logs system power - commands controlling system power system reset - reset the system using the selected firmware system sensors - print environmental sensors status system service-event - print service-event status system fru - fru related commands system watchdog - system watchdog commands BMC>
To display help information for the option of an SP/BMC command, enter
helpbefore or after the SP/BMC command.The following example shows the SP CLI online help for the SP
eventscommand.SP> help events events all - print all system events events info - print system event log information events newest - print newest system events events oldest - print oldest system events events search - search for and print system events
The following example shows the BMC CLI online help for the BMC
system powercommand.BMC> system power help system power cycle - power the system off, then on system power off - power the system off system power on - power the system on system power status - print system power status BMC>
Learn more about the commands described in this procedure in the ONTAP command reference.
Related information
