iSCSI error messages and resolutions in ONTAP
There are a number of common iSCSI-related error messages that you can view with the event log show command. You need to know what these messages mean and what you can do to resolve the issues they identify.
The following table contains the most common error messages, and instructions for resolving them:
| Message | Explanation | What to do |
The iSCSI service is not enabled on the interface. |
You can use the
CHAP is not configured correctly for the specified initiator. |
You should check the CHAP settings; you cannot use the same user name and password for inbound and outbound settings on the storage system:
Learn more about event log show in the ONTAP command reference.
