Unencrypt volume data in ONTAP
You can use the volume move start command to move and unencrypt volume data.
You must be a cluster administrator to perform this task.
Move an existing encrypted volume and unencrypt the data on the volume:
volume move start -vserver SVM_name -volume volume_name -destination-aggregate aggregate_name -encrypt-destination falseLearn more about
volume move startin the ONTAP command reference.The following command moves an existing volume named
vol1to the destination aggregateaggr3and unencrypts the data on the volume:cluster1::> volume move start -vserver vs1 -volume vol1 -destination-aggregate aggr3 -encrypt-destination false
The system deletes the encryption key for the volume. The data on the volume is unencrypted.
Verify that the volume is disabled for encryption:
volume show -encryptionLearn more about
volume showin the ONTAP command reference.The following command displays whether volumes on
cluster1are encrypted:cluster1::> volume show -encryption Vserver Volume Aggregate State Encryption State ------- ------ --------- ----- ---------------- vs1 vol1 aggr1 online none
