Volume move reference snapshot shows as the newest for ONTAP SnapMirror relationship
Use the following information if the volume move reference snapshot shows as the newest for the SnapMirror relationship after a volume move operation.
Issue:
After performing a volume move operation on a consistency group volume, the volume move reference snapshot might incorrectly display as the newest for the SnapMirror relationship.
You can view the newest snapshot with the following command:
snapmirror show -fields newest-snapshot status -expand
Solution:
Manually perform a snapmirror resync or wait for the next automatic resync operation after the volume move operation completes.
Related information
