Restore all LUNs in a volume from an ONTAP snapshot
You can use volume snapshot restore command to restore all the LUNs in a specified volume from a snapshot.
Steps
From the host, stop all host access to the LUNs.
Using SnapRestore without stopping all host access to LUNs in the volume can cause data corruption and system errors.
Unmount the LUNs on that host so that the host cannot access the LUNs.
Unmap your LUNs:
lun mapping delete -vserver <SVM_name> -volume <volume_name> -lun <lun_name> -igroup <igroup_name> -
Determine the snapshot to which you want to restore your volume:
volume snapshot show -vserver <SVM_name> -volume <volume_name> -
Change your privilege setting to advanced:
set -privilege advanced -
Restore your data:
volume snapshot restore -vserver <SVM_name> -volume <volume_name> -snapshot <snapshot_name> -
Follow the instructions on the screen.
Remap your LUNs:
lun mapping create -vserver <SVM_name> -volume <volume_name> -lun <lun_name> -igroup <igroup_name> -
Verify that your LUNs are online:
lun show -vserver <SVM_name> -path <lun_path> -fields state -
If your LUNs are not online, bring them online:
lun modify -vserver <SVM_name> -path <lun_path> -state online -
Change your privilege setting to admin:
set -privilege admin -
From the host, remount your LUNs.
From the host, restart access to your LUNs.
