Limit the output of the ONTAP show command using the fields parameter
When you use the -instance parameter with a show command to display details, the output can be lengthy and include more information than you need. The -fields parameter of a show command enables you to display only the information you specify.
For example, running volume show -instance is likely to result in several screens of information. You can use volume show -fields fieldname[,fieldname…] to customize the output so that it includes only the specified field or fields (in addition to the default fields that are always displayed.) You can use -fields ? to display valid fields for a show command.
The following example shows the output difference between the -instance parameter and the -fields parameter:
cluster1::> volume show -instance
Vserver Name: cluster1-1
Volume Name: vol0
Aggregate Name: aggr0
Volume Size: 348.3GB
Volume Data Set ID: -
Volume Master Data Set ID: -
Volume State: online
Volume Type: RW
Volume Style: flex
Space Guarantee Style: volume
Space Guarantee in Effect: true
Press <space> to page down, <return> for next line, or 'q' to quit...
cluster1::>
cluster1::> volume show -fields space-guarantee,space-guarantee-enabled
vserver volume space-guarantee space-guarantee-enabled
cluster1-1 vol0 volume true
cluster1-2 vol0 volume true
vs1 root_vol
volume true
vs2 new_vol
volume true
vs2 root_vol
volume true
cluster1::>
