ONTAP FPolicy policy worksheets
You can use this worksheet to record the values that you need during the FPolicy policy configuration process. You should record whether you want to include each parameter setting in the FPolicy policy configuration and then record the value for the parameters that you want to include.
Type of information |
Include |
Your values |
Storage virtual machine (SVM) name |
Yes |
Policy name |
Yes |
Event names |
Yes |
Persistent store |
External engine name |
Is mandatory screening required? |
Allow privileged access |
Privileged user name |
Is passthrough-read enabled? |
