ONTAP commands for remote node management
Contributors netapp-aaron-holt netapp-aherbin netapp-dbagwell netapp-sumathi netapp-barbe
You can remotely perform node-management tasks by either accessing its SP and running SP CLI commands, or accessing the BMC and running BMC CLI commands. For several commonly performed remote node-management tasks, you can also use ONTAP commands from another node in the cluster. Some SP and BMC commands are platform-specific and might not be available on your platform.
Certain command types can be used in both SP and BMC command sets. The differences between them will be shown when entering the command line.
  • The help command in SP: SP> help
  • The help command in BMC: BMC> help
Learn more about the help command options available for SP and BMC in View the help information in the ONTAP SP/BMC CLI.
Learn more about corresponding ONTAP BMC CLI in Supported CLI commands for the ONTAP Baseboard Management Controller.
If you want to…​ Use this SP command…​ Use this BMC command…​ Use this ONTAP command…​
Display available commands or subcommands of a specified command for SP/BMC/ONTAP
help [command]
help [command]
N/A
Display the current privilege level for the SP/BMC/ONTAP CLI
priv show
priv show
N/A
Set the privilege level to access the specified mode for the SP/BMC/ONTAP CLI
priv set
{admin | advanced | diag}
priv set
{admin | advanced | diag | test}
N/A
Display system date and time
date
date
date
Display events that are logged by the SP/BMC/ONTAP
events
{all | info | newest number | oldest number | search keyword}
events
{all| info | newest | oldest | search }
N/A
Display SP/BMC/ONTAP status and network configuration information
sp status
[-v | -d]
  • The -v option displays SP statistics in verbose form.
  • The -d option adds the SP debug log to the display.
bmc status
[-v | -d]
system service-processor show
Display the length of time the SP/BMC/ONTAP has been up and the average number of jobs in the run queue over the last 1, 5, and 15 minutes
sp uptime
bmc uptime
N/A
Display system console logs
system log
system log
[-a]
system log
(prints system console logs)
Display the SP/BMC/ONTAP log archives or the files in an archive
sp log history show
[-archive {latest | all | archive-name}] [-dump {all | file-name}]
bmc log history show
N/A
Display the power status for the controller of a node
system power status
system power status
system node power show
Display battery information
system battery show
system battery show
N/A
Display ACP information or the status for expander sensors
system acp
[show | sensors show]
N/A
N/A
List all system FRUs and their IDs
system fru list
system fru list
N/A
Display product information for the specified FRU
system fru show fru_id
system fru show
[ show <id> ]
N/A
Display the FRU data history log
system fru log show
(advanced privilege level)
system fru log show
N/A
Display the status for the environmental sensors, including their states and current values
system sensors
or
system sensors show
system sensors
{show | filter <sensor_string> }
system node environment sensors show
Display the status and details for the specified sensor
system sensors get sensor_name
You can obtain sensor_name by using the system sensors or the system sensors show command.
system sensors
[ get ]
N/A
Display the SP/BMC/ONTAP firmware version information
version
version
system service-processor image show
Display the SP/BMC/ONTAP command history
sp log audit
bmc log audit
N/A
Display the SP/BMC/ONTAP debug information
sp log debug
bmc log debug
N/A
Display the SP/BMC/ONTAP messages file
sp log messages
bmc log messages
N/A
Display the settings for collecting system forensics on a watchdog reset event, display system forensics information collected during a watchdog reset event, or clear the collected system forensics information
system forensics
[show | log dump | log clear]
N/A
N/A
Log in to the system console
system console
system console
system node run-console
You should press Ctrl-D to exit the system console session.
Turn the node on or off, or perform a power-cycle (turning the power off and then back on)
system power on
system power on
system node power on
system power off
system power off
N/A
system power cycle
system power cycle
N/A
The standby power stays on to keep the SP running without interruption. During the power-cycle, a brief pause occurs before power is turned back on.
Note
Using these commands to turn off or power-cycle the node might cause an improper shutdown of the node (also called a dirty shutdown) and is not a substitute for a graceful shutdown using the ONTAP system node halt command.
Create a core dump and reset the node
system core [-f]
The -f option forces the creation of a core dump and the reset of the node.
system core
system node coredump trigger
These commands have the same effect as pressing the Non-maskable Interrupt (NMI) button on a node, causing a dirty shutdown of the node and forcing a dump of the core files when halting the node. These commands are helpful when ONTAP on the node is hung or does not respond to commands such as system node shutdown. The generated core dump files are displayed in the output of the system node coredump show command. The SP stays operational as long as the input power to the node is not interrupted.
Reboot the node with an optionally specified BIOS firmware image (primary, backup, or current) to recover from issues such as a corrupted image of the node's boot device
system reset
{primary | backup | current}
system reset
{ current | primary | backup }
system node reset with the -firmware {primary | backup | current} parameter
Note
This operation causes a dirty shutdown of the node.
If no BIOS firmware image is specified, the current image is used for the reboot. The SP stays operational as long as the input power to the node is not interrupted.
Compare the current battery firmware image against a specified firmware image
system battery verify [image_URL]
If image_URL is not specified, the default battery firmware image is used for comparison.
N/A
Update the battery firmware from the image at the specified location
system battery flash [image_URL]
You use this command if the automatic battery firmware upgrade process has failed for some reason.
N/A
N/A
Update the SP/BMC/ONTAP firmware by using the image at the specified location
sp update
image_URL
image_URL must not exceed 200 characters.
bmc update
image_URL
system service-processor image update
Reboot the SP/BMC/ONTAP
sp reboot
bmc reboot
system service-processor reboot-sp
Erase the NVRAM flash content
system nvram flash clear
This command cannot be initiated when the controller power is off (system power off).
N/A
N/A
Exit the SP/BMC/ONTAP CLI
exit
exit
N/A
Related information
