The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
ONTAP commands for Service Processor management
ONTAP provides commands for managing the SP, including the SP network configuration, SP firmware image, SSH access to the SP, and general SP administration.
Commands for managing the SP network configuration
| If you want to… |
Run this ONTAP command… |
Enable the SP automatic network configuration for the SP to use the IPv4 or IPv6 address family of the specified subnet
system service-processor network auto-configuration enable
Disable the SP automatic network configuration for the IPv4 or IPv6 address family of the subnet specified for the SP
system service-processor network auto-configuration disable
Display the SP automatic network configuration
system service-processor network auto-configuration show
Manually configure the SP network for a node, including the following:
The IP address family (IPv4 or IPv6)
Whether the network interface of the specified IP address family should be enabled
If you are using IPv4, whether to use the network configuration from the DHCP server or the network address that you specify
The public IP address for the SP
The netmask for the SP (if using IPv4)
The network prefix-length of the subnet mask for the SP (if using IPv6)
The gateway IP address for the SP
system service-processor network modify
Display the SP network configuration, including the following:
The configured address family (IPv4 or IPv6) and whether it is enabled
The remote management device type
The current SP status and link status
Network configuration, such as IP address, MAC address, netmask, prefix-length of subnet mask, router-assigned IP address, link local IP address, and gateway IP address
The time the SP was last updated
The name of the subnet used for SP automatic configuration
Whether the IPv6 router-assigned IP address is enabled
SP network setup status
Reason for the SP network setup failure
system service-processor network show
Displaying complete SP network details requires the -instance parameter.
Modify the SP API service configuration, including the following:
system service-processor api-service modify
(advanced privilege level)
Display the SP API service configuration
system service-processor api-service show
Renew the SSL and SSH certificates used by the SP API service for internal communication
Commands for managing the SP firmware image
| If you want to… |
Display the details of the currently installed SP firmware image, including the following:
The image (primary or backup) that the SP is booted from, its status, and firmware version
Whether the firmware automatic update is enabled and the last update status
system service-processor image show
The -is-current parameter indicates the image (primary or backup) that the SP is currently booted from, not if the installed firmware version is most current.
Enable or disable the SP automatic firmware update
system service-processor image modify
By default, the SP firmware is automatically updated with the update of ONTAP or when a new version of the SP firmware is manually downloaded. Disabling the automatic update is not recommended because doing so can result in suboptimal or nonqualified combinations between the ONTAP image and the SP firmware image.
Manually download an SP firmware image on a node
Before you run the system node image commands, you must set the privilege level to advanced (set -privilege advanced), entering y when prompted to continue.
The SP firmware image is packaged with ONTAP. You do not need to download the SP firmware manually, unless you want to use an SP firmware version that is different from the one packaged with ONTAP.
Display the status for the latest SP firmware update triggered from ONTAP, including the following information:
system service-processor image update-progress show
Commands for managing SSH access to the SP
| If you want to… |
Grant SP access to only the specified IP addresses
system service-processor ssh add-allowed-addresses
Block the specified IP addresses from accessing the SP
system service-processor ssh remove-allowed-addresses
Display the IP addresses that can access the SP
system service-processor ssh show
Commands for general SP administration
| If you want to… |
Display general SP information, including the following:
Whether the SP network is configured
Network information, such as the public IP address and the MAC address
The SP firmware version and Intelligent Platform Management Interface (IPMI) version
Whether the SP firmware automatic update is enabled
system service-processor show Displaying complete SP information requires the -instance parameter.
system service-processor reboot-sp
Generate and send an AutoSupport message that includes the SP log files collected from a specified node
system node autosupport invoke-splog
Display the allocation map of the collected SP log files in the cluster, including the sequence numbers for the SP log files that reside in each collecting node
system service-processor log show-allocations
