Create FlexClone LUNs from a snapshot in a volume
You can use a snapshot in your volume to create FlexClone copies of your LUNs. FlexClone copies of LUNs are both readable and writeable.
A FlexClone license must be installed. This license is included with ONTAP One.
The FlexClone LUN inherits the space reservations attribute of the parent LUN. A space-reserved FlexClone LUN requires as much space as the space-reserved parent LUN. If the FlexClone LUN is not space-reserved, the volume must have enough space to accommodate changes to the clone.
Verify that the LUN is not mapped or being written to.
Create a snapshot of the volume that contains the LUNs:
volume snapshot create -vserver vserver_name -volume volume_name -snapshot snapshot_name
You must create a snapshot (the backing snapshot) of the LUN you want to clone.
Create the FlexClone LUN from the snapshot:
file clone create -vserver vserver_name -volume volume_name -source-path source_path -snapshot-name snapshot_name -destination-path destination_path
If you need the FlexClone LUN to be available for automatic deletion, you include
-autodelete true
. If you are creating this FlexClone LUN in a volume using semi-thick provisioning, you must enable automatic deletion for all FlexClone LUNs. -
Verify that the FlexClone LUN is correct:
lun show -vserver vserver_name
Vserver Path State Mapped Type Size ------- ---------------------- -------- --------- -------- ------- vs1 /vol/vol1/lun1_clone online unmapped windows 47.07MB vs1 /vol/vol1/lun1_snap_clone online unmapped windows 47.07MB
