Enable external key management for hardware-based encryption in ONTAP 9.5 and earlier
You can use one or more KMIP servers to secure the keys the cluster uses to access encrypted data. You can connect up to four KMIP servers to a node. A minimum of two servers is recommended for redundancy and disaster recovery.
ONTAP configures KMIP server connectivity for all nodes in the cluster.
The KMIP SSL client and server certificates must have been installed.
You must be a cluster administrator to perform this task.
You must configure the MetroCluster environment before you configure an external key manager.
In a MetroCluster environment, you must install the same KMIP SSL certificate on both clusters.
Configure key manager connectivity for cluster nodes:
security key-manager setupThe key manager setup starts.
In a MetroCluster environment, you must run this command on both clusters. Learn more about security key-manager setupin the ONTAP command reference. -
Enter the appropriate response at each prompt.
Add a KMIP server:
security key-manager add -address key_management_server_ipaddressclusterl::> security key-manager add -address 20.1.1.1
In a MetroCluster environment, you must run this command on both clusters. -
Add an additional KMIP server for redundancy:
security key-manager add -address key_management_server_ipaddressclusterl::> security key-manager add -address 20.1.1.2
Verify that all configured KMIP servers are connected:
security key-manager show -statusLearn more about the commands described in this procedure in the ONTAP command reference.
cluster1::> security key-manager show -status Node Port Registered Key Manager Status -------------- ---- ---------------------- --------------- cluster1-01 5696 20.1.1.1 available cluster1-01 5696 20.1.1.2 available cluster1-02 5696 20.1.1.1 available cluster1-02 5696 20.1.1.2 available
Optionally, convert plain text volumes to encrypted volumes.
volume encryption conversion startAn external key manager must be fully configured before you convert the volumes. In a MetroCluster environment, an external key manager must be configured on both sites.
