Get ONTAP AutoSupport message descriptions
The descriptions of the AutoSupport messages that you receive are available through the ONTAP Syslog Translator.
Steps
Go to the Syslog Translator.
In the Release field, enter the the version of ONTAP you are using. In the Search String field, enter "callhome". Select Translate.
The Syslog Translator will alphabetically list all events that match the message string you entered.
