Display ONTAP SMB volume mount and junction point information
You can display information about mounted volumes for storage virtual machines (SVMs) and the junction points to which the volumes are mounted. You can also determine which volumes are not mounted to a junction point. You can use this information to understand and manage your SVM namespace.
Perform the desired action:
If you want to display… Enter the command… Summary information about mounted and unmounted volumes on the SVM
volume show -vserver vserver_name -junctionDetailed information about mounted and unmounted volumes on the SVM
volume show -vserver vserver_name -volume volume_name -instanceSpecific information about mounted and unmounted volumes on the SVM
If necessary, you can display valid fields for the
-fieldsparameter by using the following command:volume show -fields ? -
Display the desired information by using the
-fieldsparameter: volume show -vserver vserver_name -fields fieldname,…
The following example displays a summary of mounted and unmounted volumes on SVM vs1:
cluster1::> volume show -vserver vs1 -junction
Junction Junction
Vserver Volume Active Junction Path Path Source
vs1 data true /data RW_volume
vs1 home4 true /eng/home RW_volume
vs1 vs1_root - / -
vs1 sales true /sales RW_volume
The following example displays information about specified fields for volumes located on SVM vs2:
cluster1::> volume show -vserver vs2 -fields vserver,volume,aggregate,size,state,type,security-style,junction-path,junction-parent,node vserver volume aggregate size state type security-style junction-path junction-parent node ------- ------ --------- ---- ------ ---- -------------- ------------- --------------- ----- vs2 data1 aggr3 2GB online RW unix - - node3 vs2 data2 aggr3 1GB online RW ntfs /data2 vs2_root node3 vs2 data2_1 aggr3 8GB online RW ntfs /data2/d2_1 data2 node3 vs2 data2_2 aggr3 8GB online RW ntfs /data2/d2_2 data2 node3 vs2 pubs aggr1 1GB online RW unix /publications vs2_root node1 vs2 images aggr3 2TB online RW ntfs /images vs2_root node3 vs2 logs aggr1 1GB online RW unix /logs vs2_root node1 vs2 vs2_root aggr3 1GB online RW ntfs / - node3
